StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC w/ DDM – 550m (Mini-GBIC)
Quicklinx: 8G5PWS00 Mfr#: SFPGESST
Type: Modules
36 In Stock
£24.09 ex VAT
£28.90 inc VAT
Add, replace or upgrade SFP modules on Gigabit fiber equipment. The SFPGESST Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC - 550m (1804 ft) is built to comply with MSA (Multi-Sourcing Agreement) standards to offer a cost-effective way to add, replace or upgrade a Multimode LC port on your Gigabit fiber networking equipment or fiber media converter.
Supporting data rates up to 1.25 Gbps as well as Digital Diagnostics Monitoring (DDM), this LC SFP/Mini-GBIC module can be installed into any fiber networking device with an MSA or Cisco compliant SFP port. Delivering both convenience and scalability, this fiber transceiver is fully hot-pluggable, which enables you to install the module without interrupting network traffic or requiring a device reboot.
This 850nm multi-mode SFP module is compatible with the Cisco SFP-GE-S transceiver.
  • Reliable connectivity
    This SFP module utilizes Ethernet 1000Base-SX cabling for wired networking, ensuring consistent performance in various applications.
  • Versatile operating conditions
    Designed to operate within a temperature range of 0°C to 70°C and a humidity range of 30% to 70%, this module offers flexibility for a range of environments.
  • Extended data transfer
    With a maximum transfer distance of 550 m, the module is ideal for expansive network setups, providing stable connections over long distances.
  • High compatibility
    This module is compatible with SFP slots, making it easy to integrate into existing networking equipment.
  • Enhanced monitoring capabilities
    Features Digital Diagnostics Monitoring Interface (DDMI) for real-time network performance assessment.
StarTech.com Cisco SFP-GE-S Compatible SFP Module, 1000BASE-SX, 1GbE Multimode Fiber MMF Optic Transceiver, 1GE Gigabit Ethernet SFP, LC 550m, 850nm, DDM, Cisco IE3400, IE3300, IE3200 - Lifetime Warranty (SFPGESST) - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - LC multi-mode
Plug-in module
Cabling Type
1000Base-SX
Optical Wave Length
850 nm
1GbE
Max Transfer Distance
550 m
1.2 cm x 6 cm x 1 cm
17 g
P/N: ET91000LCOAM, ET91000SFP2, ET91000SFP2C, IES101002SFP, MCM1110SFP, PEX1000SFP2
Plug-in module
Wired
Cabling Type
1000Base-SX
1GbE
Optical Wave Length
850 nm
550 m
Full duplex capability, half duplex mode, Digital Diagnostics Monitoring Interface (DDMI)
IEEE 802.3z
1 x Ethernet 1000Base-SX - LC multi-mode x 2
Compatible Slots
1 x SFP (mini-GBIC)
UL, FCC, RoHS
1.2 cm
6 cm
1 cm
17 g
Limited warranty - lifetime
70 °C
30 - 70%
8G5P StarTech.com Gb MM SFP Fiber Transceiver In Stock £35.36
8G5P StarTech.com 1m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £14.35
8G5P StarTech.com 10m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £24.07
8G5P StarTech.com 2m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £15.49
8G5P StarTech.com 5m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £18.84
8G5P StarTech.com 1m Single Mode Duplex Fiber Patch Cable LC-SC In Stock £16.00
8G5P StarTech.com 3m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £16.65
8G5P StarTech.com Cisco Compatible 100 Mbps Fiber SFP Transceiver Module MM LC w/ DDM - 2 km (Mini-GBIC) In Stock £36.73
8G5P StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module SM LC w/ DDM – 20 km (Mini-GBIC) In Stock £40.45
8G5P StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC w/ DDM – 550m (Mini-GBIC) In Stock £24.09
8G5P StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC – 550m (Mini-GBIC) In Stock £24.09
8G5P StarTech.com Cisco Compatible 10GBase-SR SFP+ Fiber Transceiver Module 850nm MM LC w/DDM - 300m In Stock £35.41
8G5P StarTech.com PCI Express Gigabit Ethernet Fiber Network Card w/ Open SFP - PCIe SFP Network NIC In Stock £142.63
8G5P StarTech.com Fiber Media Converter - Open In Stock £43.33
8G5P StarTech.com Gigabit Fiber SFP - 10 Pack In Stock £228.89
8G5P StarTech.com Gigabit Fiber SFP - 10 Pack In Stock £223.48
8G5P StarTech.com Gb Fiber SFP - Cisco Compatible In Stock £37.59
8G5P StarTech.com GbE Switch, 8x PoE+ 2x SFP Ports In Stock £335.67
Type: Modules
