Add, replace or upgrade SFP modules on Gigabit fiber equipment. The SFPGESST Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC - 550m (1804 ft) is built to comply with MSA (Multi-Sourcing Agreement) standards to offer a cost-effective way to add, replace or upgrade a Multimode LC port on your Gigabit fiber networking equipment or fiber media converter.
Supporting data rates up to 1.25 Gbps as well as Digital Diagnostics Monitoring (DDM), this LC SFP/Mini-GBIC module can be installed into any fiber networking device with an MSA or Cisco compliant SFP port. Delivering both convenience and scalability, this fiber transceiver is fully hot-pluggable, which enables you to install the module without interrupting network traffic or requiring a device reboot.
This 850nm multi-mode SFP module is compatible with the Cisco SFP-GE-S transceiver.
Reliable connectivity
This SFP module utilizes Ethernet 1000Base-SX cabling for wired networking, ensuring consistent performance in various applications. -
Versatile operating conditions
Designed to operate within a temperature range of 0°C to 70°C and a humidity range of 30% to 70%, this module offers flexibility for a range of environments. -
Extended data transfer
With a maximum transfer distance of 550 m, the module is ideal for expansive network setups, providing stable connections over long distances. -
High compatibility
This module is compatible with SFP slots, making it easy to integrate into existing networking equipment. -
Enhanced monitoring capabilities
Features Digital Diagnostics Monitoring Interface (DDMI) for real-time network performance assessment.
- StarTech.com Cisco SFP-GE-S Compatible SFP Module, 1000BASE-SX, 1GbE Multimode Fiber MMF Optic Transceiver, 1GE Gigabit Ethernet SFP, LC 550m, 850nm, DDM, Cisco IE3400, IE3300, IE3200 - Lifetime Warranty (SFPGESST) - SFP (mini-GBIC) transceiver module - 1GbE
- SFP (mini-GBIC) transceiver module - LC multi-mode
- Form Factor
- Plug-in module
- Cabling Type
- 1000Base-SX
- Optical Wave Length
- 850 nm
- Data Link Protocol
- 1GbE
- Max Transfer Distance
- 550 m
- 1.2 cm x 6 cm x 1 cm
- 17 g
- Limited lifetime warranty
- Designed For
- P/N: ET91000LCOAM, ET91000SFP2, ET91000SFP2C, IES101002SFP, MCM1110SFP, PEX1000SFP2
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 1000Base-SX
- 1GbE
- 850 nm
- 550 m
- Full duplex capability, half duplex mode, Digital Diagnostics Monitoring Interface (DDMI)
- IEEE 802.3z
- 1 x Ethernet 1000Base-SX - LC multi-mode x 2
- Compatible Slots
- 1 x SFP (mini-GBIC)
- UL, FCC, RoHS
- 1.2 cm
- 6 cm
- 1 cm
- 17 g
- Limited warranty - lifetime
- 0 °C
- 70 °C
- 30 - 70%
- Designed For
StarTech.com Gb MM SFP Fiber Transceiver | In Stock | £35.36 |
StarTech.com 1m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £14.35 |
StarTech.com 10m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £24.07 |
StarTech.com 2m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £15.49 |
StarTech.com 5m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £18.84 |
StarTech.com 1m Single Mode Duplex Fiber Patch Cable LC-SC | In Stock | £16.00 |
StarTech.com 3m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £16.65 |
StarTech.com Cisco Compatible 100 Mbps Fiber SFP Transceiver Module MM LC w/ DDM - 2 km (Mini-GBIC) | In Stock | £35.10 |
StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module SM LC w/ DDM – 20 km (Mini-GBIC) | In Stock | £40.45 |
StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC w/ DDM – 550m (Mini-GBIC) | In Stock | £24.09 |
StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC – 550m (Mini-GBIC) | In Stock | £24.09 |
StarTech.com Cisco Compatible 10GBase-SR SFP+ Fiber Transceiver Module 850nm MM LC w/DDM - 300m | In Stock | £35.41 |
StarTech.com PCI Express Gigabit Ethernet Fiber Network Card w/ Open SFP - PCIe SFP Network NIC | In Stock | £142.63 |
StarTech.com Fiber Media Converter - Open | In Stock | £43.33 |
StarTech.com Gigabit Fiber SFP - 10 Pack | In Stock | £228.89 |
StarTech.com Gigabit Fiber SFP - 10 Pack | In Stock | £223.48 |
StarTech.com Gb Fiber SFP - Cisco Compatible | In Stock | £37.59 |
StarTech.com GbE Switch, 8x PoE+ 2x SFP Ports | In Stock | £328.89 |
