Add, replace or upgrade SFP+ modules on 10G fiber equipment. The SFP10GSRST Cisco Compatible 10GBase-SR SFP+ Fiber Transceiver Module 850nm MM LC w/DDM - 300m (984ft) is built to comply with MSA (Multi-Sourcing Agreement) standards to offer a cost-effective way to add, replace or upgrade a 10Gb SFP+ Multimode LC port on your fiber networking equipment or fiber media converter.
Supporting data rates up to 11.1 Gbps as well as Digital Diagnostics Monitoring (DDM), this LC SFP+/Mini-GBIC module can be installed into any fiber networking device with an MSA or Cisco compliant 10GbE SFP+ port. Delivering both convenience and scalability, this fiber transceiver is fully hot-pluggable, which enables you to install the module without interrupting network traffic or requiring a device reboot.
This 850nm multi-mode SFP+ module is compatible with the Cisco SFP-10G-SR transceiver.
Reliable performance
The SFP+ transceiver module facilitates efficient networking with a data link protocol of 10 Gigabit Ethernet, ensuring swift data exchange for demanding applications. -
Flexible compatibility
Compliant with various standards such as UL, FCC, RoHS, and MSA, this module supports a diverse range of networking environments and ensures ease of integration. -
Advanced functionality
Equipped with digital diagnostics, the module provides detailed operational insights, enhancing network management and troubleshooting capabilities.
 - StarTech.com Cisco SFP-10G-SR Compatible SFP+ Module, 10GBASE-SR, 10GbE Multimode Fiber MMF Optic Transceiver, 10GE Gigabit Ethernet SFP+, LC 300m, 850nm, DDM, Cisco Firepower, ASR9000 - Lifetime Warranty (SFP10GSRST) - SFP+ transceiver module - 10GbE
 - SFP+ transceiver module - LC multi-mode
- Form Factor
 - Plug-in module
- Cabling Type
 - 10GBase-SR
- Data Transfer Rate
 - 11.1 Gbps
- Optical Wave Length
 - 850 nm
- Data Link Protocol
 - 10GbE
- Max Transfer Distance
 - 300 m
 - 1.2 cm x 6 cm x 1 cm
 - 17 g
 - Limited lifetime warranty
- Designed For
 - P/N: ET10GSFP, PEX10000SFP, PEX10000SFPI, PEX10GSFP, PEX10GSFP4I, PEX20000SFPI
- Form Factor
 - Plug-in module
- Connectivity Technology
 - Wired
- Cabling Type
 - 10GBase-SR
 - 10GbE
 - 11.1 Gbps
 - 850 nm
 - 300 m
 - Half duplex mode, full duplex mode, Digital Diagnostics
 - IEEE 802.3ae
 - 1 x Ethernet 10GBase-SR - LC multi-mode female x 2
- Compatible Slots
 - 1 x SFP+
 - UL, FCC, RoHS, Laser Class 1, MSA
 - 1.2 cm
 - 6 cm
 - 1 cm
 - 17 g
 - Limited warranty - lifetime
 - 0 °C
 - 70 °C
 - 30 - 70%
- Designed For
                        StarTech.com 2m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC | In Stock | £18.69 |
                        StarTech.com 1m Single Mode Duplex Fiber Patch Cable LC-SC | In Stock | £17.11 |
                        StarTech.com Cisco Compatible 100 Mbps Fiber SFP Transceiver Module MM LC w/ DDM - 2 km (Mini-GBIC) | In Stock | £34.79 |
                        StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module SM LC w/ DDM – 20 km (Mini-GBIC) | In Stock | £40.09 |
                        StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC w/ DDM – 550m (Mini-GBIC) | In Stock | £23.89 |
                        StarTech.com Cisco Compatible 10GBase-SR SFP+ Fiber Transceiver Module 850nm MM LC w/DDM - 300m | In Stock | £35.09 |
                        StarTech.com 3m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC | In Stock | £20.42 |
                        StarTech.com 10m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC | In Stock | £32.44 |
                        StarTech.com 1m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC | In Stock | £16.84 |
                        StarTech.com 5m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC | In Stock | £23.93 |
                        StarTech.com 2-Port 10G Fiber NIC-Open SFP+ | In Stock | £288.42 |
                        StarTech.com 10 Gigabit Fiber SFP+ Transceiver Module SM LC | In Stock | £203.79 |
