StarTech.com Cisco Compatible 10GBase-SR SFP+ Fiber Transceiver Module 850nm MM LC w/DDM - 300m
Quicklinx: 8M4FWS00 Mfr#: SFP10GSRST
Type: Modules
£36.81 ex VAT
£44.17 inc VAT
Add, replace or upgrade SFP+ modules on 10G fiber equipment. The SFP10GSRST Cisco Compatible 10GBase-SR SFP+ Fiber Transceiver Module 850nm MM LC w/DDM - 300m (984ft) is built to comply with MSA (Multi-Sourcing Agreement) standards to offer a cost-effective way to add, replace or upgrade a 10Gb SFP+ Multimode LC port on your fiber networking equipment or fiber media converter.
Supporting data rates up to 11.1 Gbps as well as Digital Diagnostics Monitoring (DDM), this LC SFP+/Mini-GBIC module can be installed into any fiber networking device with an MSA or Cisco compliant 10GbE SFP+ port. Delivering both convenience and scalability, this fiber transceiver is fully hot-pluggable, which enables you to install the module without interrupting network traffic or requiring a device reboot.
This 850nm multi-mode SFP+ module is compatible with the Cisco SFP-10G-SR transceiver.
  • Reliable performance
    The SFP+ transceiver module facilitates efficient networking with a data link protocol of 10 Gigabit Ethernet, ensuring swift data exchange for demanding applications.
  • Flexible compatibility
    Compliant with various standards such as UL, FCC, RoHS, and MSA, this module supports a diverse range of networking environments and ensures ease of integration.
  • Advanced functionality
    Equipped with digital diagnostics, the module provides detailed operational insights, enhancing network management and troubleshooting capabilities.
StarTech.com Cisco SFP-10G-SR Compatible SFP+ Module, 10GBASE-SR, 10GbE Multimode Fiber MMF Optic Transceiver, 10GE Gigabit Ethernet SFP+, LC 300m, 850nm, DDM, Cisco Firepower, ASR9000 - Lifetime Warranty (SFP10GSRST) - SFP+ transceiver module - 10GbE
SFP+ transceiver module - LC multi-mode
Plug-in module
Cabling Type
10GBase-SR
Data Transfer Rate
11.1 Gbps
Optical Wave Length
850 nm
10GbE
Max Transfer Distance
300 m
1.2 cm x 6 cm x 1 cm
17 g
P/N: ET10GSFP, PEX10000SFP, PEX10000SFPI, PEX10GSFP, PEX10GSFP4I, PEX20000SFPI
Plug-in module
Wired
Cabling Type
10GBase-SR
10GbE
Data Transfer Rate
11.1 Gbps
Optical Wave Length
850 nm
300 m
Half duplex mode, full duplex mode, Digital Diagnostics
IEEE 802.3ae
1 x Ethernet 10GBase-SR - LC multi-mode female x 2
Compatible Slots
1 x SFP+
UL, FCC, RoHS, Laser Class 1, MSA
1.2 cm
6 cm
1 cm
17 g
Limited warranty - lifetime
70 °C
30 - 70%
8M4F StarTech.com 2m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC In Stock £19.53
8M4F StarTech.com 1m Single Mode Duplex Fiber Patch Cable LC-SC In Stock £16.69
8M4F StarTech.com Cisco Compatible 100 Mbps Fiber SFP Transceiver Module MM LC w/ DDM - 2 km (Mini-GBIC) In Stock £36.55
8M4F StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module SM LC w/ DDM – 20 km (Mini-GBIC) In Stock £41.49
8M4F StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC w/ DDM – 550m (Mini-GBIC) In Stock £25.06
8M4F StarTech.com Cisco Compatible 10GBase-SR SFP+ Fiber Transceiver Module 850nm MM LC w/DDM - 300m In Stock £36.81
8M4F StarTech.com 3m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC In Stock £17.93
8M4F StarTech.com 10m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC In Stock £34.49
8M4F StarTech.com 1m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC In Stock £17.60
8M4F StarTech.com 5m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC In Stock £25.04
8M4F StarTech.com 2-Port 10G Fiber NIC-Open SFP+ In Stock £304.01
8M4F StarTech.com 10 Gigabit Fiber SFP+ Transceiver Module SM LC In Stock £214.57
Type: Modules
