Add, replace or upgrade SFP modules on 100 Mbps fiber equipment. The SFPF1302C Cisco Compatible Fast Ethernet Fiber SFP Transceiver Module MM LC - 2 km (1.2 miles) is built to comply with MSA (Multi-Sourcing Agreement) standards to offer a cost-effective way to add, replace or upgrade a Multimode LC port on your 100 Mbps fiber networking equipment or fiber media converter.
Featuring data rates of up to 155 Mbps and support for Digital Diagnostics Monitoring (DDM), this LC SFP module can be installed into any fiber networking device with an MSA or Cisco compliant SFP port. Delivering convenience and scalability, the fiber transceiver is fully hot-pluggable, enabling you to install the module without interrupting network traffic or requiring a device reboot.
This 1300nm multi-mode SFP module is compatible with the Cisco GLC-FE-100FX transceiver.
- StarTech.com Cisco GLC-FE-100FX Compatible SFP Module, 100BASE-FX, 100Mbps Multimode Fiber MMF Optic Transceiver, 100 Mbps, LC Connector, 2km, 1310nm, DDM, Cisco ASR920, IE2000, IE4000 - Lifetime Warranty (SFPF1302C) - SFP (mini-GBIC) transceiver module - 100Mb LAN
- SFP (mini-GBIC) transceiver module - LC multi-mode
- Form Factor
- Plug-in module
- Cabling Type
- 100Base-FX
- Data Transfer Rate
- 155 Mbps
- Optical Wave Length
- 1310 nm
- Data Link Protocol
- 100Mb LAN
- Max Transfer Distance
- 2 km
- 0.9 cm x 6.5 cm x 1.4 cm
- 25 g
- Limited lifetime warranty
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 100Base-FX
- 100Mb LAN
- 155 Mbps
- 1310 nm
- 2 km
- Full duplex capability, half duplex mode, Digital Diagnostics Monitoring Interface (DDMI)
- IEEE 802.3u
- 1 x Ethernet 100Base-FX - LC multi-mode
- Compatible Slots
- 1 x SFP (mini-GBIC)
- FCC, RoHS, MSA
- 0.9 cm
- 6.5 cm
- 1.4 cm
- 25 g
- Limited warranty - lifetime
- 0 °C
- 70 °C
StarTech.com Gb MM SFP Fiber Transceiver | In Stock | £42.40 |
StarTech.com 1m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £16.24 |
StarTech.com 10m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £27.07 |
StarTech.com 2m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £17.35 |
StarTech.com 30m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £53.67 |
StarTech.com 5m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £21.55 |
StarTech.com 3m Multimode 50/125 Duplex Fiber Patch Cable LC - LC | In Stock | £18.85 |
StarTech.com Cisco Compatible 100 Mbps Fiber SFP Transceiver Module MM LC w/ DDM - 2 km (Mini-GBIC) | In Stock | £42.81 |
StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module SM LC w/ DDM – 20 km (Mini-GBIC) | In Stock | £43.98 |
StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC w/ DDM – 550m (Mini-GBIC) | In Stock | £26.13 |
StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC – 550m (Mini-GBIC) | In Stock | £26.13 |
StarTech.com Cisco Compatible 10GBase-SR SFP+ Fiber Transceiver Module 850nm MM LC w/DDM - 300m | In Stock | £38.40 |
