StarTech.com Cisco Compatible 100 Mbps Fiber SFP Transceiver Module MM LC w/ DDM - 2 km (Mini-GBIC)
Quicklinx: 82HMWS00 Mfr#: SFPF1302C
Type: Modules
12 in stock
£40.15 ex VAT
£48.18 inc VAT
Add, replace or upgrade SFP modules on 100 Mbps fiber equipment. The SFPF1302C Cisco Compatible Fast Ethernet Fiber SFP Transceiver Module MM LC - 2 km (1.2 miles) is built to comply with MSA (Multi-Sourcing Agreement) standards to offer a cost-effective way to add, replace or upgrade a Multimode LC port on your 100 Mbps fiber networking equipment or fiber media converter.
Featuring data rates of up to 155 Mbps and support for Digital Diagnostics Monitoring (DDM), this LC SFP module can be installed into any fiber networking device with an MSA or Cisco compliant SFP port. Delivering convenience and scalability, the fiber transceiver is fully hot-pluggable, enabling you to install the module without interrupting network traffic or requiring a device reboot.
This 1300nm multi-mode SFP module is compatible with the Cisco GLC-FE-100FX transceiver.
StarTech.com Cisco GLC-FE-100FX Compatible SFP Module - Lifetime Warranty - SFP (mini-GBIC) transceiver module - 100Mb LAN
SFP (mini-GBIC) transceiver module - LC multi-mode
Plug-in module
Cabling Type
100Base-FX
Data Transfer Rate
155 Mbps
Optical Wave Length
1310 nm
100Mb LAN
Max Transfer Distance
2 km
0.9 cm x 6.5 cm x 1.4 cm
25 g
Plug-in module
Wired
Cabling Type
100Base-FX
100Mb LAN
Data Transfer Rate
155 Mbps
Optical Wave Length
1310 nm
2 km
Full duplex capability, half duplex mode, Digital Diagnostics Monitoring Interface (DDMI)
IEEE 802.3u
1 x Ethernet 100Base-FX - LC multi-mode
Compatible Slots
1 x SFP (mini-GBIC)
FCC, RoHS, MSA
0.9 cm
6.5 cm
1.4 cm
25 g
Limited warranty - lifetime
70 °C
82HM StarTech.com Gb MM SFP Fiber Transceiver In Stock £53.83
82HM StarTech.com 10m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £18.47
82HM StarTech.com 2m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £12.05
82HM StarTech.com 30m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £34.85
82HM StarTech.com 3m Multimode 50/125 Duplex Fiber Patch Cable LC - LC In Stock £12.91
82HM StarTech.com Cisco Compatible 100 Mbps Fiber SFP Transceiver Module MM LC w/ DDM - 2 km (Mini-GBIC) In Stock £40.15
82HM StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module SM LC w/ DDM – 20 km (Mini-GBIC) In Stock £71.70
Type: Modules
Price Range Ex VAT: 0 - 50
