StarTech.com CFexpress Type B Card Reader
Quicklinx: HVLZWS00 Mfr#: 1B-USB-C-CFE-ADAPTER
£20.07 ex VAT
£24.08 inc VAT
The StarTech.com USB-C CFexpress Type B Card Reader is a versatile and efficient solution for professionals who require fast and reliable data transfer. With its USB-C 3.2 Gen 2 interface, this card reader offers speeds of up to 10 Gbps, making it suitable for quickly accessing, transferring, and backing up large files. It supports both CFexpress 2.0 Card Type-B and XQD memory cards, providing flexibility for users with different storage needs. The integrated USB cable ensures that connectivity is always within reach, while the device's USB bus-powered design enhances its portability, eliminating the need for an external power source. Additionally, the card reader's status indicator offers immediate operational feedback, simplifying the user experience. Whether you're a photographer, videographer, or any professional in need of a reliable data transfer solution, the StarTech.com card reader is designed to meet your needs.
  • High-speed data transfer
    Experience swift file transfers with the USB-C 3.2 Gen 2 interface, offering speeds of up to 10 Gbps. This feature ensures efficient workflow and quick access to your CFexpress 2.0 Card Type-B and XQD memory card content, making it suitable for professionals on-the-go.
  • Convenient and portable design
    Designed with an integrated USB cable measuring 20 cm, this card reader is highly convenient. Its compact, external enclosure allows for easy transportation, and being USB bus powered, it eliminates the need for an external power source, making it ideal for fieldwork.
  • User-friendly operation
    The card reader comes equipped with a status indicator, providing real-time feedback on the device's operation. This feature, combined with its Plug-and-Play functionality, ensures a hassle-free user experience, allowing you to focus more on your work and less on setup.
StarTech.com USB-C CFexpress Type B Card Reader, CF Express 2.0 Adapter - card reader - USB-C 3.2 Gen 2
Card reader - external
Supported Memory Cards
XQD Memory Card, CFexpress 2.0 Card Type B
Host Interface
USB-C 3.2 Gen 2
Status indicator, USB bus powered, up to 10 Gbps data transfer, integrated USB cable (20cm)
Host Interface
USB-C 3.2 Gen 2
4.5 cm
1.2 cm
50 g
Memory Card
(max)
Required Ports
1 x 24 pin USB-C
WEEE
Shipping Width
17 cm
Shipping Depth
10 cm
Shipping Height
3 cm
Shipping Weight
100 g
HVLZ StarTech.com SD Express Card Reader In Stock £33.05
