StarTech.com CFast/SATA Adapter
Quicklinx: BFP5WS00 Mfr#: CFAST2SAT25
£20.29 ex VAT
£24.34 inc VAT
Convert your CFast card into a 2.5in SATA drive for faster data transfer. Now you can use your CFast memory card like a standard 2.5" SATA solid-state drive. This unique adapter lets you access and recover data from a CFast card through SATA at faster data transfer speeds.
This CFast to SATA adapter creates a permanent conversion from CFast to SATA for use inside small form factor or embedded solutions. The drive frame and the connector on the adapter mimic the exact size and connector location of a 2.5" SATA hard drive.
Standard 2.5" housing allows the converted card to be installed into a laptop or other standard mounting bracket. Once the CFast card is mounted inside this adapter, you can use it just like a 2.5" SATA drive - in your laptop, docking station, enclosure or desktop computer.
Transfer data from your CFast card to your PC through SATA, with file transfer speeds of up to 6 Gbps. You can offload data from your DSLR cameras and camcorders, or transfer graphic design files, videos and other files from your CFast card.
Faster file transfer speeds means you'll spend less time waiting for file transfers to complete. The actual speed will depend on the speed of the CFast media.
StarTech.com CFast Card to SATA Adapter with 2.5" Housing - Supports SATA III (6 Gbps) - CFast Memory Card Converter - OS Independent (CFAST2SAT25) - storage controller - CFast Card - SATA 6Gb/s
Storage controller - internal
Bus Type
SATA 6Gb/s
Black, silver
CFast Card
Data Transfer Rate
6 GBps
Supported Devices
Hard drive
Channel Qty
1
6.8 cm x 9.8 cm x 0.98 cm
50 g
P/N: BRACKET125PT, BRACKET125PTP, BRACKET225PT, BRACKET425F
Host Bus
SATA 6Gb/s
Black, silver
Storage Controller
CFast Card
Data Transfer Rate
6 GBps
Supported Devices
Hard drive
Channel Qty
1
1 x CFast Card - 24 pin CFast
1 - 22 pin Serial ATA
FCC, RoHS
6.8 cm
9.8 cm
0.98 cm
50 g
BFP5 StarTech.com 24" Serial ATA Cable In Stock £5.28
BFP5 StarTech.com 18" Serial ATA Cable w/R Angle In Stock £5.00
BFP5 StarTech.com 36in SATA Serial ATA Cable In Stock £5.70
BFP5 StarTech.com 24in SATA to Right Angle SATA Serial ATA Cable In Stock £5.50
BFP5 StarTech.com 12in Latching SATA Cable In Stock £6.16
BFP5 StarTech.com 12in Latching SATA to Right Angle SATA Serial ATA Cable In Stock £5.24
BFP5 StarTech.com 6in Latching SATA Cable In Stock £2.60
BFP5 StarTech.com 12in SATA to Left Angle SATA Serial ATA Cable In Stock £5.42
BFP5 StarTech.com M.2 to U.2 Adapter In Stock £23.11
