Quicklinx: CZCBWS00 Mfr#: CTKRPR
Hurry, only 3 left in stock!
£17.09 ex VAT
£20.50 inc VAT
This tool kit provides all of the essential screwdrivers, bits, tweezers and spudgers, you'll need to repair virtually any smartphone, tablet or laptop. It's the perfect addition to your electronics repair bench, for working on a wide range of mobile devices. Approach your repair with confidence, knowing you have the right tools on hand for all devices from the major technology brands. Save time and frustration with a single tool kit, that has everything you'll need for cell phone, tablet and smartphone repair.
  • Comprehensive toolkit
    This cell phone repair kit from StarTech.com is designed to meet all your gadget repair needs, featuring a wide array of essential tools including screwdriver bits in various sizes, spudgers, a SIM card eject tool, suction cup, triangular pry tool, and tweezers, all neatly organized in a durable case.
  • Precision and versatility
    Equipped with specialized tools such as tri-wing, pentalobe, torx, hex, and slot screwdriver bits, this kit ensures you have the precise tool for the job, whether you're working on smartphones, computers, or other electronics.
  • Portable and organized
    The included case not only protects your tools but also keeps them neatly organized, making it easy to carry everything you need for repairs on the go.
StarTech.com Cell Phone Repair Kit - with Case - Multipurpose - Computer Tool Kit - Electronics Kit - PC Tool Kit (CTKRPR) - mobile phone repair tool set - 23 pieces
Mobile phone repair tool set - 23 pieces
Package Content
2 spudgers, triangular pry tool, tweezers, screwdriver handle, 5 screwdriver bits - torx T4, T5, T6, T8, T10, 4 screwdriver bits - phillips PH000, PH00, PH0, PH1, 3 screwdriver bits - pentalobe 0.8, 1.2, 1.6 mm, 2 screwdriver bits - tri-wing TRI0, TRI1, screwdriver bit - slot 2 mm, screwdriver bit - hex 2 mm, suction cup, SIM card eject tool
Holder
Case
Tool Set (pieces)
23
Package Content
Holder
Case
Warranty
2 years
10.8 cm
17.1 cm
4.1 cm
295 g
CZCB StarTech.com 11 Piece PC Computer Tool Kit with Carrying Case In Stock £14.09
CZCB StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit In Stock £20.00
CZCB StarTech.com 20-Bit Electric Precision Screwdriver Set In Stock £43.02
CZCB StarTech.com 55-Bit Electric Precision Screwdriver Set In Stock £59.62
CZCB StarTech.com 23x47in Anti Static Mat In Stock £43.16
CZCB StarTech.com 11x18in Anti Static Mat In Stock £24.84
CZCB StarTech.com Temperature/Humidity Meter In Stock £24.79
CZCB StarTech.com Handheld Sound Level Meter In Stock £27.14
Device Type: Smartphone
Type: Repair kit
Product Range: StarTech.com
Product Model: Cell Phone Repair Kit - with Case - Multipurpose - Computer Tool Kit - Electronics Kit - PC Tool Kit (CTKRPR)
