StarTech.com Ceiling TV Mount - Steel
Quicklinx: CRY8WS00 Mfr#: FPCEILPTBSP
Accessory Type: Mount
£113.64 ex VAT
£136.36 inc VAT
Securely mount your flat-panel TV to a ceiling or overhead structure, and customize your viewing angle with easy position adjustments. Save space and create the ultimate viewing environment for your flat-screen television, by suspending it from the ceiling. This flat-screen TV ceiling mount supports VESA mount compatible TVs 37" to 70" in size. For maximum viewing versatility, the ceiling mount makes it easy to adjust the distance from the ceiling and offers a full-motion design that lets you change your screen position and angle.
The ceiling TV mount lets you mount your flat-panel LCD, LED or plasma TV in a prominent and comfortable viewing area while saving wall, desk and floor space. It's ideal for use in corporate boardrooms, hotel lobbies, restaurants, bars and meeting spaces.
The heavy-duty steel TV ceiling mount is compatible with a wide selection of TVs, able to securely support a 37 to 70" display, with a weight capacity of up to 110 lb. (50 kg). To keep the cables concealed and organized, you simply run the cables through the cable management channel inside of the pole, exiting near the top.
With an adjustable pole length, the telescopic-style pole makes it easy to mount your display at the desired distance from the ceiling and works well with a range of ceiling heights. The robust steel pole can extend from a minimum of 22" to 35.8" (560 mm to 910 mm) at maximum length, with a total lift (height extension) of 13.7" (350 mm).
The flat-screen TV ceiling mount is designed to accommodate a wide variety of ceiling types. The ceiling mount swivels, so you can adjust the mount to work with virtually any type of ceiling for level viewing, including sloped ceilings (up to 60°), and pitched or horizontal (flat) ceilings. The extension pole also swivels + 180° / - 180° for optimum viewing.
You can adjust your flat-screen TV to create a comfortable viewing angle, by tilting it (up to -25°) down towards your audience for optimum visibility. The full-motion mount lets you tilt or swivel your display around the pole, without using tools. The ceiling mount also features a 360° pan, which makes it easy to set up for viewing from any direction you choose.
The hook-and-mount design of the TV ceiling mount makes setup fast and easy. You simply attach the vertical brackets, with built-in hooks, to the back of your TV. Once the brackets are attached, you can hang your TV securely onto the ceiling mount. The preset leveling adjustments ensure ideal positioning after hanging.
  • Adjustable Height
    With a telescopic pole, the TV mount lets you suspend a display at your desired distance from the ceiling. This works well with a range of ceiling heights. The steel pole can extend from 22" to 33.5" (560 to 910 mm), with a total lift (height extension) of 13.7" (350 mm).
  • Swivels to Suit Your Ceiling
    The flat-screen ceiling mount accommodates a wide variety of ceiling types. You can swivel the TV to work with virtually any type of ceiling for level viewing, including sloped ceilings (up to 60 degrees), and pitched or horizontal (flat) ceilings.
  • Viewable from Any Direction
    You can adjust your TV to create a comfortable viewing angle, by tilting it up to -25 degrees down towards your audience for optimum visibility. Plus, the full-motion mount lets you swivel your display around the pole + 180 / - 180 degrees, without using tools.
  • Hook-and-Mount Design
    Simply attach the included vertical brackets, with built-in hooks, to the back of your TV. Once attached, hang your TV securely onto the ceiling mount. The +/-3 degree post-installation leveling adjustments ensure ideal positioning after hanging. FPCEILPTBSP is backed by a StarTech.com 5-year warranty and free lifetime technical support.
StarTech.com Ceiling TV Mount - 1.8' to 3' Short Pole - Full Motion - Supports Displays 32" to 75" - For VESA Mount Compatible TVs (FPCEILPTBSP) bracket - for flat panel - black
Bracket - ceiling mountable
43.5 cm x 68 cm x 1.128 m
Adjustable Height
56-91 cm
Tilt
0° to 25°
Pan
-180° to 180°
Lift
35 cm
Rotation
360°
Adjustments
Height, pan, tilt, swivel, rotation
Recommended Use
Flat panel
Recommended Display Size
37"-75"
VESA Mounting Interface
200 x 200 mm, 400 x 200 mm, 400 x 400 mm, 600 x 400 mm, 300 x 300 mm
Max Load Weight
50 kg
Material
Heavy duty steel
Package Content
Mounting hardware
5-year warranty
P/N: HDMIPLATE
43.5 cm
68 cm
1.128 m
Adjustable Height
56-91 cm
Material
Heavy duty steel
Package Content
Mounting hardware
AV Furniture
Bracket
Recommended Use
Flat panel
Placing / Mounting
Ceiling mountable
Cable Management
Integrated cable management
37"-75"
Tilt
0° to 25°
Pan
-180° to 180°
Lift
35 cm
Rotation
360°
Adjustments
Max Load Weight
50 kg
Limited warranty - 5 years
P/N: HDMIPLATE
CRY8 StarTech.com SPDIF Digital Coaxial or Toslink Optical to Stereo RCA Audio Converter In Stock £36.95
CRY8 StarTech.com 15 ft Thin Toslink Digital Optical SPDIF Audio Cable In Stock £5.32
CRY8 StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £15.83
CRY8 StarTech.com Flat-Screen TV Ceiling Mount In Stock £112.86
CRY8 StarTech.com Ceiling TV Mount - Steel In Stock £113.64
CRY8 StarTech.com Ceiling TV Mount - Long Pole In Stock £155.22
CRY8 StarTech.com 10m CL2 Active HDMI Cable - 4K In Stock £78.22
CRY8 StarTech.com Ceiling TV Mount, Back-to-Back In Stock £233.42
