Elevate your network's performance and reliability with the StarTech.com 5m White CAT8 Ethernet Cable. Designed for high-speed data transfer and online gaming, this cable supports speeds up to 40 Gbps and bandwidths up to 2000 MHz. Its S/FTP design, featuring aluminum mylar foil with braid shielding, minimizes interference, ensuring a stable and secure connection. The cable is constructed with a Low Smoke Zero Halogen (LSZH) jacket, making it safe and durable, while the snagless design prevents connector damage during installation. With 100W PoE++ support, it simplifies installations by delivering power and data through a single cable. The gold-plated connectors and pure bare copper conductors ensure minimal signal loss and high performance. Compliant with key standards, this patch cable is a versatile and reliable choice for any networking setup.
Enhanced connectivity
Experience seamless network performance with the 5m White CAT8 Ethernet Cable, featuring up to 40 Gbps speed for high-speed data transfer and online gaming. Its S/FTP design ensures minimal interference, making it ideal for demanding Internet and network tasks. -
Durable design
Constructed with a Low Smoke Zero Halogen (LSZH) jacket and snagless design, this cable is built for both safety and longevity. The flame-retardant materials and strain relief add an extra layer of durability, ensuring a reliable connection for years to come. -
Efficient power and data delivery
With 100W PoE++ support, this cable is not just about speed; it's also about power. Power over Ethernet (PoE) allows devices like security cameras and VoIP phones to receive both power and data through a single cable, simplifying installations and reducing cable clutter. -
High-quality construction
Featuring pure bare copper conductors and gold-plated connectors, this cable ensures high performance and minimal signal loss. The aluminum mylar foil with braid shielding further protects against electromagnetic interference (EMI), ensuring a clean, stable connection. -
Advanced compatibility
Meeting and exceeding various standards, including IEEE 802.3bt/IEEE 802.3ba and TIA/EIA T568B, this cable is designed for universal compatibility. It supports a wide range of devices and is tested to perform up to 2000 MHz, making it a versatile choice for any networking setup.
- StarTech.com 5m White CAT8 Ethernet Cable, Snagless, S/FTP, 25G/40G - patch cable - 5 m - white
- Patch cable - CAT 5/5e/6/6a/8 - IEEE 802.3bt/IEEE 802.3ba
- Technology
- S/FTP
- Wiring Scheme
- T568B
- Shielding Material
- Aluminum mylar foil with braid
- Wires per Cable
- 8 wires
- Halogen-free, snagless, flame retardant, strain relief, test fluke pass, pure bare copper conductors, up to 40 Gbps, EMI protection, 100W PoE++ support
- Length
- 5 m
- Diameter
- 5.6 mm
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- White
- Limited lifetime warranty
- Network Cable Type
- Technology
- S/FTP
- Wiring Scheme
- T568B
- Jacket Material
- Low Smoke Zero Halogen (LSZH)
- American Wire Gauge (AWG)
- 26
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Plated Connector
- Gold
- Length
- 5 m
- Diameter
- 5.6 mm
- White
- Connector
- RJ-45 - male
- RJ-45 - male
- WEEE, TIA/EIA T568B - up to 2000 MHz
- Shipping Width
- 18 cm
- Shipping Depth
- 20 cm
- Shipping Height
- 3 cm
- Shipping Weight
- 206 g
- 0 °C
- 50 °C
