StarTech.com CAT8 Ethernet Cable, LSZH - 5m
Quicklinx: HQ22WS00 Mfr#: NLWH-5M-CAT8-PATCH
£35.64 ex VAT
£42.76 inc VAT
Elevate your network's performance and reliability with the StarTech.com 5m White CAT8 Ethernet Cable. Designed for high-speed data transfer and online gaming, this cable supports speeds up to 40 Gbps and bandwidths up to 2000 MHz. Its S/FTP design, featuring aluminum mylar foil with braid shielding, minimizes interference, ensuring a stable and secure connection. The cable is constructed with a Low Smoke Zero Halogen (LSZH) jacket, making it safe and durable, while the snagless design prevents connector damage during installation. With 100W PoE++ support, it simplifies installations by delivering power and data through a single cable. The gold-plated connectors and pure bare copper conductors ensure minimal signal loss and high performance. Compliant with key standards, this patch cable is a versatile and reliable choice for any networking setup.
  • Enhanced connectivity
    Experience seamless network performance with the 5m White CAT8 Ethernet Cable, featuring up to 40 Gbps speed for high-speed data transfer and online gaming. Its S/FTP design ensures minimal interference, making it ideal for demanding Internet and network tasks.
  • Durable design
    Constructed with a Low Smoke Zero Halogen (LSZH) jacket and snagless design, this cable is built for both safety and longevity. The flame-retardant materials and strain relief add an extra layer of durability, ensuring a reliable connection for years to come.
  • Efficient power and data delivery
    With 100W PoE++ support, this cable is not just about speed; it's also about power. Power over Ethernet (PoE) allows devices like security cameras and VoIP phones to receive both power and data through a single cable, simplifying installations and reducing cable clutter.
  • High-quality construction
    Featuring pure bare copper conductors and gold-plated connectors, this cable ensures high performance and minimal signal loss. The aluminum mylar foil with braid shielding further protects against electromagnetic interference (EMI), ensuring a clean, stable connection.
  • Advanced compatibility
    Meeting and exceeding various standards, including IEEE 802.3bt/IEEE 802.3ba and TIA/EIA T568B, this cable is designed for universal compatibility. It supports a wide range of devices and is tested to perform up to 2000 MHz, making it a versatile choice for any networking setup.
StarTech.com 5m White CAT8 Ethernet Cable, Snagless, S/FTP, 25G/40G - patch cable - 5 m - white
Patch cable - CAT 5/5e/6/6a/8 - IEEE 802.3bt/IEEE 802.3ba
S/FTP
Wiring Scheme
T568B
Shielding Material
Wires per Cable
8 wires
Halogen-free, snagless, flame retardant, strain relief, test fluke pass, pure bare copper conductors, up to 40 Gbps, EMI protection, 100W PoE++ support
Length
5 m
Diameter
5.6 mm
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
White
Network Cable Type
S/FTP
Wiring Scheme
T568B
Shielding Material
Jacket Material
American Wire Gauge (AWG)
26
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
5 m
Diameter
5.6 mm
White
Connector
RJ-45 - male
RJ-45 - male
WEEE, TIA/EIA T568B - up to 2000 MHz
Shipping Width
18 cm
Shipping Depth
20 cm
Shipping Height
3 cm
Shipping Weight
206 g
50 °C
