StarTech.com CAT8 Ethernet Cable, LSZH - 3m
Quicklinx: HQ20WS00 Mfr#: NLWH-3M-CAT8-PATCH
Length: 3m
Colour: White
£29.27 ex VAT
£35.12 inc VAT
Elevate your network's performance and reliability with the StarTech.com 3m White CAT8 Ethernet Cable. Designed for professional environments that demand fast data transfer and stable connections, this patch cable supports speeds of up to 40 Gbps, making it ideal for video streaming, high-speed data transfer, and gaming. Its construction features pure bare copper conductors and a Low Smoke Zero Halogen (LSZH) jacket, ensuring both safety and durability. The cable is equipped with EMI protection and 100W PoE++ support, catering to advanced networking requirements. Its snagless design and strain relief further enhance its durability, making it a reliable choice for any setup. Compliant with IEEE 802.3bt/IEEE 802.3ba and TIA/EIA T568B standards, this cable ensures compatibility and optimal performance in a wide range of network configurations.
  • High-speed connectivity
    Experience fast data transfer speeds of up to 40 Gbps, enabling efficient and rapid file sharing, video streaming, and gaming. This cable's support for 25G/40G networks ensures your setup is ready for high-demand applications.
  • Enhanced durability
    Constructed with pure bare copper conductors and protected by a Low Smoke Zero Halogen (LSZH) jacket, this cable is designed for both safety and longevity. The snagless design and strain relief add an extra layer of durability, ensuring a secure connection and extended lifespan.
  • Superior performance
    Featuring EMI protection and tested to pass Fluke tests, this cable provides reliable performance in various environments. Its compliance with IEEE standards and TIA/EIA T568B wiring scheme ensures compatibility and optimal performance in professional setups.
StarTech.com 3m White CAT8 Ethernet Cable, Snagless, S/FTP, 25G/40G - patch cable - 3 m - white
Patch cable - CAT 5/5e/6/6a/8 - IEEE 802.3bt/IEEE 802.3ba
S/FTP
Wiring Scheme
T568B
Shielding Material
Wires per Cable
8 wires
Halogen-free, snagless, flame retardant, strain relief, test fluke pass, pure bare copper conductors, up to 40 Gbps, EMI protection, 100W PoE++ support
Length
3 m
Diameter
5.6 mm
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
White
Network Cable Type
S/FTP
Wiring Scheme
T568B
Shielding Material
Jacket Material
American Wire Gauge (AWG)
26
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
3 m
Diameter
5.6 mm
White
Connector
RJ-45 - male
RJ-45 - male
WEEE, TIA/EIA T568B - up to 2000 MHz
Shipping Width
19 cm
Shipping Depth
22 cm
Shipping Height
2 cm
Shipping Weight
131 g
50 °C
Length: 3m
Colour: White
