The StarTech.com 12m White CAT8 Ethernet Cable is a high-quality network solution designed for sophisticated networking needs. This snagless, S/FTP patch cable is a significant upgrade over standard network cables, supporting data transmission speeds of up to 40 Gbps and bandwidths up to 2000 MHz. Engineered with high-quality materials including pure bare copper conductors and gold-plated connectors, it ensures minimal signal loss and high performance.
Ideal for both professional and home networks, this cable features 100W PoE++ support, allowing devices to be powered over the network, which helps reduce cable clutter. Its Low Smoke Zero Halogen (LSZH) jacket and flame-retardant properties ensure safety in all environments. Whether setting up a new network or upgrading an existing one, the StarTech.com CAT8 cable provides the reliability and performance needed for high-speed networking tasks.
                Enhanced connectivityExperience seamless network performance with the 12m White CAT8 Ethernet Cable, designed for high-speed data transmission up to 40 Gbps. Its S/FTP technology ensures minimal interference, making it ideal for demanding network environments.
                Durable designBuilt with a Low Smoke Zero Halogen (LSZH) jacket and featuring snagless, halogen-free construction, this cable is designed for both safety and longevity. The pure bare copper conductors and strain relief add to its durability, ensuring a stable connection.
                High performanceEquipped with gold-plated connectors and aluminum mylar foil with braid shielding, the cable offers exceptional EMI protection and 100W PoE++ support. Its compliance with IEEE standards and TIA/EIA T568B wiring scheme validates its quality and reliability.
- StarTech.com 12m White CAT8 Ethernet Cable, Snagless, S/FTP, 25G/40G - patch cable - 12 m - white
- Patch cable - CAT 5/5e/6/6a/8 - IEEE 802.3bt/IEEE 802.3ba
- Technology
- S/FTP
- Wiring Scheme
- T568B
- Shielding Material
- Aluminum mylar foil with braid
- Wires per Cable
- 8 wires
- Halogen-free, snagless, flame retardant, strain relief, test fluke pass, pure bare copper conductors, up to 40 Gbps, EMI protection, 100W PoE++ support
- Length
- 12 m
- Diameter
- 5.6 mm
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- White
- Limited lifetime warranty
- Network Cable Type
- Technology
- S/FTP
- Wiring Scheme
- T568B
- Jacket Material
- Low Smoke Zero Halogen (LSZH)
- American Wire Gauge (AWG)
- 26
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Plated Connector
- Gold
- Length
- 12 m
- Diameter
- 5.6 mm
- White
- Connector
- RJ-45 - male
- RJ-45 - male
- WEEE, TIA/EIA T568B - up to 2000 MHz
- Shipping Width
- 22 cm
- Shipping Depth
- 31 cm
- Shipping Height
- 4.5 cm
- Shipping Weight
- 500 g
- 0 °C
- 50 °C
