StarTech.com CAT8 Ethernet Cable, LSZH - 12m
Quicklinx: HQ1WWS00 Mfr#: NLWH-12M-CAT8-PATCH
Length: 12m
Colour: White
10 In Stock
£84.85 ex VAT
£101.82 inc VAT
The StarTech.com 12m White CAT8 Ethernet Cable is a high-quality network solution designed for sophisticated networking needs. This snagless, S/FTP patch cable is a significant upgrade over standard network cables, supporting data transmission speeds of up to 40 Gbps and bandwidths up to 2000 MHz. Engineered with high-quality materials including pure bare copper conductors and gold-plated connectors, it ensures minimal signal loss and high performance.
Ideal for both professional and home networks, this cable features 100W PoE++ support, allowing devices to be powered over the network, which helps reduce cable clutter. Its Low Smoke Zero Halogen (LSZH) jacket and flame-retardant properties ensure safety in all environments. Whether setting up a new network or upgrading an existing one, the StarTech.com CAT8 cable provides the reliability and performance needed for high-speed networking tasks.
  • Enhanced connectivity
    Experience seamless network performance with the 12m White CAT8 Ethernet Cable, designed for high-speed data transmission up to 40 Gbps. Its S/FTP technology ensures minimal interference, making it ideal for demanding network environments.
  • Durable design
    Built with a Low Smoke Zero Halogen (LSZH) jacket and featuring snagless, halogen-free construction, this cable is designed for both safety and longevity. The pure bare copper conductors and strain relief add to its durability, ensuring a stable connection.
  • High performance
    Equipped with gold-plated connectors and aluminum mylar foil with braid shielding, the cable offers exceptional EMI protection and 100W PoE++ support. Its compliance with IEEE standards and TIA/EIA T568B wiring scheme validates its quality and reliability.
StarTech.com 12m White CAT8 Ethernet Cable, Snagless, S/FTP, 25G/40G - patch cable - 12 m - white
Patch cable - CAT 5/5e/6/6a/8 - IEEE 802.3bt/IEEE 802.3ba
S/FTP
Wiring Scheme
T568B
Shielding Material
Wires per Cable
8 wires
Halogen-free, snagless, flame retardant, strain relief, test fluke pass, pure bare copper conductors, up to 40 Gbps, EMI protection, 100W PoE++ support
Length
12 m
Diameter
5.6 mm
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
White
Network Cable Type
S/FTP
Wiring Scheme
T568B
Shielding Material
Jacket Material
American Wire Gauge (AWG)
26
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
12 m
Diameter
5.6 mm
White
Connector
RJ-45 - male
RJ-45 - male
WEEE, TIA/EIA T568B - up to 2000 MHz
Shipping Width
22 cm
Shipping Depth
31 cm
Shipping Height
4.5 cm
Shipping Weight
500 g
50 °C
Length: 12m
Colour: White
