StarTech.com CAT8 Ethernet Cable, LSZH - 0.5m
Quicklinx: HQ21WS00 Mfr#: NLWH-50C-CAT8-PATCH
Length: 50cm
Colour: White
£12.49 ex VAT
£14.98 inc VAT
The StarTech.com 50cm White CAT8 Ethernet Cable is a high-performance network solution designed for superior connectivity and safety. With support for data transfer speeds of up to 40 Gbps, this patch cable is ideal for high-speed Internet connections, streaming, and gaming. Its snagless design and strain relief ensure durability and longevity, while the EMI protection and shielded construction ensure minimal signal interference. The cable is also equipped with a Low Smoke Zero Halogen (LSZH) jacket, significantly reducing the emission of toxic and corrosive gases in case of fire. Compliant with IEEE standards and supporting 100 W PoE++, it is a choice for advanced networking requirements.
  • High-speed connectivity
    Experience fast data transfer speeds of up to 40 Gbps, enabling efficient networking for demanding applications.
  • Enhanced durability
    Featuring a snagless design and strain relief, this cable is built for longevity, reducing the risk of damage during installation and daily use.
  • Superior signal integrity
    With EMI protection and a shielded aluminum mylar foil with braid, this cable ensures minimal signal interference, delivering clear and reliable connections.
  • Safety first
    The Low Smoke Zero Halogen (LSZH) jacket material minimizes toxic and corrosive gas emission in the event of a fire, ensuring a safer environment for all users.
  • Future-proof networking
    Compliant with IEEE standards and supporting 100 W PoE++, this cable is designed to meet the needs of future networking technologies and power over Ethernet applications.
StarTech.com 50cm White CAT8 Ethernet Cable, Snagless, S/FTP, 25G/40G - patch cable - 50 cm - white
Patch cable - CAT 5/5e/6/6a/8 - IEEE 802.3bt/IEEE 802.3ba
S/FTP
Wiring Scheme
T568B
Shielding Material
Wires per Cable
8 wires
Halogen-free, snagless, flame retardant, strain relief, test fluke pass, pure bare copper conductors, up to 40 Gbps, EMI protection, 100W PoE++ support
Length
50 cm
Diameter
5.6 mm
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
White
Network Cable Type
S/FTP
Wiring Scheme
T568B
Shielding Material
Jacket Material
American Wire Gauge (AWG)
26
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
50 cm
Diameter
5.6 mm
White
Connector
RJ-45 - male
RJ-45 - male
WEEE, TIA/EIA T568B - up to 2000 MHz
Shipping Width
20 cm
Shipping Depth
22 cm
Shipping Height
0.8 cm
Shipping Weight
37 g
50 °C
Length: 50cm
Colour: White
