The StarTech.com 50cm White CAT8 Ethernet Cable is a high-performance network solution designed for superior connectivity and safety. With support for data transfer speeds of up to 40 Gbps, this patch cable is ideal for high-speed Internet connections, streaming, and gaming. Its snagless design and strain relief ensure durability and longevity, while the EMI protection and shielded construction ensure minimal signal interference. The cable is also equipped with a Low Smoke Zero Halogen (LSZH) jacket, significantly reducing the emission of toxic and corrosive gases in case of fire. Compliant with IEEE standards and supporting 100 W PoE++, it is a choice for advanced networking requirements.
High-speed connectivity
Experience fast data transfer speeds of up to 40 Gbps, enabling efficient networking for demanding applications. -
Enhanced durability
Featuring a snagless design and strain relief, this cable is built for longevity, reducing the risk of damage during installation and daily use. -
Superior signal integrity
With EMI protection and a shielded aluminum mylar foil with braid, this cable ensures minimal signal interference, delivering clear and reliable connections. -
Safety first
The Low Smoke Zero Halogen (LSZH) jacket material minimizes toxic and corrosive gas emission in the event of a fire, ensuring a safer environment for all users. -
Future-proof networking
Compliant with IEEE standards and supporting 100 W PoE++, this cable is designed to meet the needs of future networking technologies and power over Ethernet applications.
 - StarTech.com 50cm White CAT8 Ethernet Cable, Snagless, S/FTP, 25G/40G - patch cable - 50 cm - white
 - Patch cable - CAT 5/5e/6/6a/8 - IEEE 802.3bt/IEEE 802.3ba
- Technology
 - S/FTP
- Wiring Scheme
 - T568B
- Shielding Material
 - Aluminum mylar foil with braid
- Wires per Cable
 - 8 wires
 - Halogen-free, snagless, flame retardant, strain relief, test fluke pass, pure bare copper conductors, up to 40 Gbps, EMI protection, 100W PoE++ support
- Length
 - 50 cm
- Diameter
 - 5.6 mm
- Connector
 - RJ-45 - male
- Connector (Second End)
 - RJ-45 - male
 - White
 - Limited lifetime warranty
- Network Cable Type
- Technology
 - S/FTP
- Wiring Scheme
 - T568B
- Jacket Material
 - Low Smoke Zero Halogen (LSZH)
- American Wire Gauge (AWG)
 - 26
- Wires per Cable
 - 8 wires
- Pairs per Cable
 - 4 pairs
- Plated Connector
 - Gold
- Length
 - 50 cm
- Diameter
 - 5.6 mm
 - White
- Connector
 - RJ-45 - male
 - RJ-45 - male
 - WEEE, TIA/EIA T568B - up to 2000 MHz
- Shipping Width
 - 20 cm
- Shipping Depth
 - 22 cm
- Shipping Height
 - 0.8 cm
- Shipping Weight
 - 37 g
 - 0 °C
 - 50 °C
