Make Gigabit Ethernet connections with PoE support. The N6PATC1MRD Cat 6 patch cable (1m) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable red PVC jacket that enables you to color code your network cable runs as needed.
To ensure long-lasting performance, this high quality Cat 6 patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles, reducing the risk of cable failure.
Get the highest value for your cable investment with the Cat 6 cables, each one manufactured using high-quality copper conductors.
Rely on RJ45 connectors to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
                Reliable connectivityThe 1 m CAT6 Ethernet Cable features RJ-45 connectors on both ends, providing a solid and secure connection for various networking devices.
                Durable constructionThe cable is made from high-quality PVC jacket material, offering protection against wear and tear, ensuring longevity in any environment.
                Efficient data transmissionWith a tested frequency of up to 500 MHz, this cable minimizes interference and supports fast data transfer rates for optimal performance.
                Snagless designThe snagless feature prevents the connectors from snagging during installation, reducing the risk of damage to the cable and network ports.
                Compliance with standardsThis cable meets ETL and RoHS standards, ensuring it is safe for use and adheres to requirements for quality and safety.
- StarTech.com 1m CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, Red, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATC1MRD) - patch cable - 1 m - red
- Patch cable - CAT 6
- Technology
- Wiring Scheme
- T568B
- Snagless, minimised Near-End Crosstalk (NEXT)
- Length
- 1 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Red
- Limited lifetime warranty
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Pairs per Cable
- 4 pairs
- Plated Connector
- Gold
- Length
- 1 m
- Red
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS, ETL, TIA/EIA-568-B - up to 500 MHz
|  | StarTech.com 1m Black Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £3.83 |
|  | StarTech.com 1m Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £3.87 |
|  | StarTech.com 1m Green Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £3.90 |
|  | StarTech.com 1m Gray Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £3.89 |
|  | StarTech.com 1m White Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £3.85 |
|  | StarTech.com 1m Yellow Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £4.06 |
|  | StarTech.com Cat6 patch cable with snagless RJ45 connectors 1M red | In Stock | £3.87 |
|  | StarTech.com Cat6 patch cable with snagless RJ45 connectors 1M Orange | In Stock | £3.79 |
|  | StarTech.com 1m Purple Cat6 Patch Cable | In Stock | £3.87 |
