StarTech.com Cat6 patch cable with snagless RJ45 connectors 1M Orange
Quicklinx: B457WS00 Mfr#: N6PATC1MOR
Length: 1m
Colour: Orange
41 In Stock
£3.79 ex VAT
£4.54 inc VAT
Make Gigabit Ethernet connections with PoE support. The N6PATC1MOR Cat 6 patch cable (1m) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable orange PVC jacket that enables you to color code your network cable runs as needed.
To ensure long-lasting performance, this high quality Cat 6 patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles, reducing the risk of cable failure.
Get the highest value for your cable investment with the Cat 6 cables, each one manufactured using high-quality copper conductors.
Rely on RJ45 connectors to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
StarTech.com 1m CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, Orange, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATC1MOR) - patch cable - 1 m - orange
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Snagless, minimised Near-End Crosstalk (NEXT)
Length
1 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Orange
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
1 m
Orange
Connector
RJ-45 - male
RJ-45 - male
RoHS, ETL, TIA/EIA-568-B - up to 500 MHz
B457 StarTech.com 1m Black Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £3.84
B457 StarTech.com 1m Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £3.87
B457 StarTech.com 1m Green Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £3.90
B457 StarTech.com 1m Gray Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £3.89
B457 StarTech.com 1m White Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £3.86
B457 StarTech.com 1m Yellow Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £4.06
B457 StarTech.com Cat6 patch cable with snagless RJ45 connectors 1M red In Stock £3.88
B457 StarTech.com Cat6 patch cable with snagless RJ45 connectors 1M Orange In Stock £3.79
B457 StarTech.com 1m Purple Cat6 Patch Cable In Stock £3.88
Length: 1m
Colour: Orange
