StarTech.com Cat6 Patch Cable - Shielded (SFTP) - 1m Blue
Quicklinx: BWG6WS00 Mfr#: N6SPAT1MBL
Length: 1m
Colour: Blue
£7.38 ex VAT
£8.85 inc VAT
Deliver high-performance Gigabit network connections, free of noise and EMI/RFI interference. This 1-meter Cat6 cable meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections. The cable is shielded to protect your network against electromagnetic interference (EMI/RFI) and system noise, providing the perfect solution for fast and safe network connections.
Constructed with 100% copper and foil-shielded twisted-pair wiring, this cable delivers high-quality performance. It's designed to keep the data signals traveling through your network free from interference, so it's perfect in environments that are prone to large amounts of EMI.
The 50-micron gold connectors deliver optimum conductivity and eliminate signal loss due to oxidation or corrosion.
For easier cable runs, the snagless connectors protect the RJ45 clips during installation, making them less likely to snag or break. This ensures a sturdy connection by preventing the cable from becoming loose from the port.
Plus, the molded boots offer strain relief that stops the RJ45 connector termination points from bending at sharp angles, which reduces the risk of damage to the cable that could decrease network performance.
StarTech.com 1m CAT6 Ethernet Cable, 10 Gigabit Shielded Snagless RJ45 100W PoE Patch Cord, CAT 6 10GbE SFTP Network Cable w/Strain Relief, Blue, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 26AWG (N6SPAT1MBL) - patch cable - 1 m - blue
Patch cable - CAT 6
Shielded foiled twisted pair (SFTP)
Wires per Cable
8 wires
Molded, snagless
Length
1 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
Network Cable Type
Patch cable - CAT 6
Jacket Material
PVC
American Wire Gauge (AWG)
26
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Molded, snagless
Length
1 m
Blue
Connector
RJ-45 - male
RJ-45 - male
RoHS, TIA/EIA-568-B - up to 500 MHz
BWG6 StarTech.com Cat6 Patch Cable - Shielded (SFTP) - 1m Blue In Stock £7.38
BWG6 StarTech.com Cat6 Patch Cable - Shielded (SFTP) - 0.5m Blue In Stock £7.16
BWG6 StarTech.com 5m Blue Cat6 SFTP Cable In Stock £12.18
BWG6 StarTech.com 2m Blue Cat6 SFTP Cable In Stock £7.78
BWG6 StarTech.com 3m Blue Cat6 / Cat 6 Shielded (SFTP) Patch Cable In Stock £9.45
Length: 1m
Colour: Blue
