Only the best-quality components are used when StarTech.com's expert manufacturing team creates its cable supplies and this gender changer is no different. This RJ45COUPLER joins two RJ45 cables together to form one long cable.
Efficient connectivity
This network coupler features RJ-45 connectors on both ends, allowing for the smooth connection of Ethernet cables. The dual female design ensures that extension is simple and effective. -
Versatile applications
Suitable for various networking setups, this coupler is ideal for both home and office use. It enables the connection of multiple devices, enhancing network efficiency.
- StarTech.com Cat5e RJ45 Modular Inline Coupler - modular inline coupler - Ethernet coupler - cat5e coupler - network coupler
- Network coupler
- Connector
- RJ-45 - female
- Connector (Second End)
- RJ-45 - female
- Limited lifetime warranty
- Network Cable Type
- Network coupler
- Connector
- RJ-45 - female
- RJ-45 - female
StarTech.com Cat5e RJ45 Modular Inline Coupler | In Stock | £5.15 |
StarTech.com White Cat 6 RJ45 Keystone Jack Network Coupler - F/F | In Stock | £8.09 |
StarTech.com Cat5e RJ45 Modular Inline Coupler - 10 Pack | In Stock | £15.73 |
StarTech.com RJ45 Cat6 Coupler, 5-Pack | In Stock | £33.38 |
StarTech.com Shielded RJ45 Coupler, Cat6a | In Stock | £13.67 |
