Make Fast Ethernet network connections using this high-quality Cat5e cable, with Power-over-Ethernet capability. The 45PAT1MWH Cat5e patch cable (1m) meets or exceeds all Cat 5e cable specifications to ensure reliable Ethernet network connections, and features a durable white PVC jacket that enables you to color code your network cable runs as needed.
To ensure long-lasting performance, this high-quality Cat5e patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles, reducing the risk of cable failure.
Get the highest value for your cable investment with the Cat 5e cables, each one manufactured using high-quality copper conductors.
Rely on the RJ45 connectors to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
- StarTech.com 1m White Cat5e / Cat 5 Snagless Patch Cable - patch cable - 1 m - white
- Patch cable - CAT 5e
- Technology
- Wires per Cable
- 8 wires
- Riser, snagless, minimised Near-End Crosstalk (NEXT)
- Length
- 1 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- White
- Limited lifetime warranty
- Network Cable Type
- Technology
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Plated Connector
- Gold
- Length
- 1 m
- White
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS - up to 350 MHz
StarTech.com 1m Gray Cat 5e Patch Cable | In Stock | £2.69 |
StarTech.com 1m Green Cat 5e Patch Cable | In Stock | £2.68 |
StarTech.com 1m Blue Cat 5e Patch Cable | In Stock | £2.68 |
StarTech.com 1m Black Cat 5e Patch Cable | In Stock | £2.69 |
StarTech.com Cat5e Patch Cable with Snagless RJ45 Connectors 1m - Orange | In Stock | £2.58 |
StarTech.com Cat5e Patch Cable with Snagless RJ45 Connectors 1m - Yellow | In Stock | £0.67 |
StarTech.com Cat5e Patch Cable with Snagless RJ45 Connectors 1m - White | In Stock | £0.67 |
StarTech.com Cat5e Patch Cable with Snagless RJ45 Connectors 1m - Red | In Stock | £2.58 |
