StarTech.com Cat 6 RJ45 Stranded Modular Plug Connector - 50 Pack
Quicklinx: FSHVWS00 Mfr#: CRJ45C6STR50
Length: [N/A]
Colour: Clear
Hurry, only 3 left in stock!
£20.60 ex VAT
£24.72 inc VAT
This Cat 6 RJ45 Modular Plug can be used with Cat 6 bulk cables, allowing you to easily terminate your Cat 6 cable to the exact length required.
  • Durable Stranded Design
    These connectors feature a stranded design, optimizing flexibility and ensuring secure connections in various installations.
  • RJ-45 Male Connectors
    Equipped with male RJ-45 connectors, these modular plugs are compatible with standard Ethernet cabling, facilitating easy connectivity.
StarTech.com Cat 6 RJ45 Stranded Modular Plug Connector - 50 Pack (CRJ45C6STR50) - network connector - clear
Network connector - CAT 6
Packaged Quantity
50 (specifications are for single item)
Stranded
Connector
RJ-45 - male
Clear
P/N: R300WN22MO5E, R300WN22MO5G, R300WN22MOD, R300WN22MOD5, R300WN22ODE, R300WN22ODG
Packaged Quantity
Network Cable Type
Stranded
Clear
Connector
RJ-45 - male
RoHS
Length: [N/A]
Colour: Clear
