StarTech.com Cable Management Sleeve
Quicklinx: GVLJWS00 Mfr#: WKSTNCMFLX
Device Type: [N/A]
Type: Cable sleeving kit
Device Screen Size: [N/A]
Colour: Black
More than 50 In Stock
£10.45 ex VAT
£12.54 inc VAT
This flexible and lightweight mesh cable management sleeve, made from polyester and woven nylon fabric, provides the solution to cable clutter. Keep cables organized behind your computer monitor, while providing access to cables when needed.
  • Convenient Cable Management
    Hook-and-loop fasteners enable quick and convenient access to cable bundles. The sleeve expands to accommodate additional cables as needed. No tools are required and cables may remain connected when inserted into the cable management sleeve.
  • Trims to any length
    Using sharp scissors, you can cut the cable-management sleeve to your desired length, to fit neatly under your desk or table, or behind your media center. The WKSTNCMFLX is backed by a StarTech.com 2-year warranty and free 24/5 lifetime technical support.
StarTech.com 10ft (3m) Cable Management Sleeve, Trimmable Heavy Duty Cable Wrap, 1.2" (3cm) Dia Polyester Mesh Computer Cable Manager/Protector/Concealer - Black Cord Organizer/Hider, Floor Cable Cover, Wire Wraps (WKSTNCMFLX) - cable management sleeve
Cable management sleeve
Product Material
Nylon, polyester
Length
3 m
For cable diameter 18 - 32 mm, hook-and-loop fasteners mounting, flexible mesh design
Product Material
Nylon, polyester
Length
3 m
Diameter
3 cm
22 cm x 20 cm x 10 cm / 73.3 g
RoHS
Limited warranty: - 2 years
Device Type: [N/A]
Colour: Black
