This flexible and lightweight mesh cable management sleeve, made from polyester and woven nylon fabric, provides the solution to cable clutter. Keep cables organized behind your computer monitor, while providing access to cables when needed.
Convenient Cable Management
Hook-and-loop fasteners enable quick and convenient access to cable bundles. The sleeve expands to accommodate additional cables as needed. No tools are required and cables may remain connected when inserted into the cable management sleeve. -
Trims to any length
Using sharp scissors, you can cut the cable-management sleeve to your desired length, to fit neatly under your desk or table, or behind your media center. The WKSTNCMFLX is backed by a StarTech.com 2-year warranty and free 24/5 lifetime technical support.
- StarTech.com 10ft (3m) Cable Management Sleeve, Trimmable Heavy Duty Cable Wrap, 1.2" (3cm) Dia Polyester Mesh Computer Cable Manager/Protector/Concealer - Black Cord Organizer/Hider, Floor Cable Cover, Wire Wraps (WKSTNCMFLX) - cable management sleeve
- Product Type
- Cable management sleeve
- Black
- Product Material
- Nylon, polyester
- Length
- 3 m
- For cable diameter 18 - 32 mm, hook-and-loop fasteners mounting, flexible mesh design
- 2-year warranty
- Product Type
- Product Material
- Nylon, polyester
- Length
- 3 m
- Diameter
- 3 cm
- Shipping Dimensions (WxDxH) / Weight
- 22 cm x 20 cm x 10 cm / 73.3 g
- Black
- RoHS
- Limited warranty: - 2 years
