StarTech.com Cable Management Sleeve - 2 m
Quicklinx: D2N1WS00 Mfr#: WKSTNCM
Select:
14 In Stock
£10.17 ex VAT
£12.20 inc VAT
Organize your workstation cables with this adjustable cable manager, and trim the fabric to your desired length. This flexible and lightweight cable-management sleeve, made of polyester and nylon fabric, provides an easy and inexpensive solution to cable clutter. Use it to keep cables organized behind your computer monitor, while still providing access to cables when needed.
Simply open the rolled fabric to guide your cables through. The flexible sleeve automatically recoils to wrap around your cables. It can also expand to cover additional cables as needed. There are no tools required, and the cables do not need to be disconnected from the computer to be inserted into the cable-management sleeve.
Using sharp scissors, you can cut the cable-management sleeve to your desired length, to fit neatly under your desk or table, or behind your media center.
StarTech.com 6.5' (2m) Cable Management Sleeve, Flexible Coiled Cable Wrap, 1.0-1.5" dia. Expandable Sleeve, Polyester Cord Manager/Protector/Concealer, Black Trimmable Cable Organizer - Flame Resistant UL94-V0 - cable sleeving kit
Cable sleeving kit
Product Material
Nylon, polyester
2.5 cm 2.5 cm
Length
2 m
85 g
Cable sleeving kit
Product Material
Nylon, polyester
2.5 cm
2.5 cm
Length
2 m
85 g
Limited warranty: - 2 years
D2N1 StarTech.com Cable Management Spine In Stock £15.04
D2N1 StarTech.com Cable Management Sleeve - Spiral - Expandable - 25mm x 2.5m In Stock £14.05
D2N1 StarTech.com Cable Management Sleeve - Spiral - Expandable - 45mm x 2.5m In Stock £14.24
D2N1 StarTech.com Cable Management Sleeve - Spiral - Expandable - 25mm x 1.5m In Stock £7.58
D2N1 StarTech.com Rack Cable Management D-Ring In Stock £15.40
