StarTech.com Cable Management Module for Conference Table Conne Box
Quicklinx: FKF1WS00 Mfr#: MOD4CABLEH
£20.99 ex VAT
£25.18 inc VAT
Cable Organizer Includes 4x Grommet Holes Installs in BOX4MODULE or BEZ4MOD. This cable-management module adds convenient cable access to the StarTech.com single-module (BEZ4MOD) or dual-module (BOX4MODULE) conference table connectivity box (each sold separately).
Conveniently Organize Your Cables
Modern office environments need to support technology more than ever, to keep laptops, phones and tablets connected. During meetings, lectures and conferences, you may need to connect your devices to equipment in your boardroom or huddle space.
The cable organizer keeps your equipment cables easily accessible, free from tangles, and out of sight. When combined with the BOX4MODULE, the cable module also lets you connect cables to the bottom-facing ports (ports facing the floor) on a separate module installed in the box, so that you can access the ports from the table top.
Customize to Your Exact Needs
Architectural connectivity is quickly becoming the trend when designing a meeting space. StarTech.com cable-management modules let you:
Organize cables according to the specific needs of your space
Install in easy to access locations
The module comes with two cable organizer brackets. Both brackets combined are the size of a full module. You can replace a missing bracket from the BOX4MODULE with half of this module, or you can add additional cable brackets to the box. You can also install both brackets into the BEZ4MOD.
MOD4CABLEH is backed by a StarTech.com 2-year warranty and free lifetime technical support.
  • Conveniently Organize Your Cables
    Modern office environments?need to support technology more than ever, to keep laptops, phones and tablets connected. During meetings, lectures and conferences, you may need to connect your devices to equipment in your boardroom or huddle space. The cable organizer keeps your equipment cables easily accessible, free from tangles, and out of sight. When combined with the BOX4MODULE, the cable module also lets you connect cables to the bottom-facing ports (ports facing the floor) on a separate module installed in the box, so that you can access the ports from the table top.
  • Customize to Your Exact Needs
    Architectural connectivity is quickly becoming the trend when designing a meeting space. StarTech.com cable-management modules let you: • Organize cables according to the specific needs of your space • Install in easy to access locations The module comes with two cable organizer brackets. Both brackets combined are the size of a full module. You can replace a missing bracket from the BOX4MODULE with half of this module, or you can add additional cable brackets to the box. You can also install both brackets into the BEZ4MOD. MOD4CABLEH is backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com Cable Management Module for Conference Table Connectivity Box - Includes 4x Grommet Holes - Installs in BOX4MODULE or BEZ4MOD (MOD4CABLEH) - cable organizer
Cable organizer
Package Content
2 mounting brackets, 4 cable management top plates, cable management bracket mounting screw, 8 cable management plate screws, 2 large cable bushings, 2 small cable bushings
60 cm x 70 cm
Product Material
Plastic, aluminium
P/N: BEZ4MOD, BOX4MODULE
Cable organizer
Package Content
Product Material
Plastic, aluminium
60 cm
70 cm
Enclosure Colour
Shipping Weight
1.1 kg
FKF1 StarTech.com Dual-Module Conference Table Connectivity Box In Stock £151.63
FKF1 StarTech.com Laptop Docking Module Conference Table Connectivity Box 4K In Stock £274.78
FKF1 StarTech.com Conference Table Box w/Docking In Stock £357.64
FKF1 StarTech.com Table Box Laptop Dock & Power In Stock £556.23
