Quicklinx: CVXNWS00 Mfr#: CMLB10
15 In Stock
£46.71 ex VAT
£56.05 inc VAT
These lacing bars install horizontally on the front or back of your rack to provide a secure mounting point for you to run cables. You can attach your cables to the lacing bars using cable ties to reduce the tension on your cables and prevent damage to the ports on your rack-mount equipment.
Cable lacing bars protect your equipment by offloading the weight of the cables in your rack, which reduces the constant strain that can be put on the ports of your rack equipment. The lacing bars also provide a route for cables, which enhances passive cooling within your rack. This helps to ensure your rack remains at an optimal temperature, to extend the life of your equipment and minimize or eliminate downtime.
These cable lacing bars are constructed of solid steel and occupy just one-third of a rack U at each install point. The round solid-steel design ensures a high weight capacity, unlike flat lacing bars that can bend easily.
This package includes 10 cable lacing bars, enabling you to buy multiple bars packaged together. This is ideal for large-scale implementations, because it significantly reduces the packaging, and in turn, shipping costs.
StarTech.com Horizontal Lacing Bar - Server Rack Cable Management - 19" Network Rack Mount Cord Organizer- 10 pack (CMLB10) - rack cable management lacing bar - 1U
Rack cable management lacing bar
Packaged Quantity
10 (specifications are for single item)
Package Content
2 screws, 2 M5 cage nuts
Height (Rack Units)
1U
Product Material
Steel
0.7 cm 1.1 cm
Length
48.3 cm
Horizontal orientation
Packaged Quantity
Product Material
Steel
Package Content
Height (Rack Units)
1U
0.7 cm
1.1 cm
Length
48.3 cm
95 g
Limited warranty: - 2 years
CVXN StarTech.com 1U Rack-Mount Cable Lacing Bar In Stock £11.93
Product Type: Rack cable management lacing bar
