The 57-0000076-01-ST is a Brocade 57-0000076-01 compatible fiber transceiver module that has been designed, programmed and tested to work with Brocade brand switches and routers. It delivers dependable 10 GbE connectivity over fiber cable, for 10GBase-LR compliant networks, with a maximum distance of up to 10 km (6.2 mi).
This SFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
 - StarTech.com Brocade 57-0000076-01 Compatible SFP+ Module, 10GBASE-LR, 10GbE Single Mode (SMF) Fiber SMF Optic Transceiver, 10GE Gigabit Ethernet SFP+, LC 10km, 1310nm, DDM, Mini GBIC SFP+ - Lifetime Warranty (57-0000076-01-ST) - SFP+ transceiver module - 10GbE
 - SFP+ transceiver module - LC single-mode
- Form Factor
 - Plug-in module
- Cabling Type
 - 10GBase-LR
- Data Transfer Rate
 - 10 Gbps
- Optical Wave Length
 - 1310 nm
- Data Link Protocol
 - 10GbE
- Max Transfer Distance
 - 10 km
- OEM Manufacturer Equivalent Part Number
 - Brocade 57-0000076-01
 - 5.84 cm x 1.39 cm x 1.37 cm
 - 21 g
 - Limited lifetime warranty
- Form Factor
 - Plug-in module
- Connectivity Technology
 - Wired
- Cabling Type
 - 10GBase-LR
 - 10GbE
 - 10 Gbps
 - 1310 nm
 - 10 km
 - Digital Diagnostics Monitoring (DDM)
 - 1 x Ethernet 10GBase-LR - LC single-mode female x 2
- MTBF
 - 1,386,624,697 hours
 - FCC, MSA
 - 1.3 Watt
 - 5.84 cm
 - 1.39 cm
 - 1.37 cm
 - 21 g
- Shipping Width
 - 9 cm
- Shipping Depth
 - 11.5 cm
- Shipping Height
 - 3.1 cm
- Shipping Weight
 - 50 g
 - Limited warranty - lifetime
