StarTech.com Brocade 10G-SFPP-SR Compatible SFP+ MM Module - 10GBase-SR
Quicklinx: FJ9VWS00 Mfr#: 10G-SFPP-SR-ST
Type: Modules
£31.26 ex VAT
£37.51 inc VAT
The 10G-SFPP-SR-ST is a Brocade 10G-SFPP-SR compatible fiber transceiver module that has been designed, programmed and tested to work with Brocade brand switches and routers. It delivers dependable 10 GbE connectivity over fiber cable, for 10GBase-SR compliant networks, with a maximum distance of up to 200 m (656 ft).
This SFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com Brocade 10G-SFPP-SR Compatible SFP+ Module, 10GBASE-SR, 10GbE Multimode Fiber MMF Optic Transceiver, 10GE Gigabit Ethernet SFP+, LC 200m, 850nm, DDM, Mini GBIC SFP+ Module - Lifetime Warranty (10G-SFPP-SR-ST) - SFP+ transceiver module - 10GbE
SFP+ transceiver module - LC multi-mode
Plug-in module
Cabling Type
10GBase-SR
Data Transfer Rate
10 Gbps
Optical Wave Length
850 nm
10GbE
Max Transfer Distance
200 m
Brocade 10G-SFPP-SR
5.84 cm x 1.39 cm x 1.26 cm
20 g
Plug-in module
Wired
Cabling Type
10GBase-SR
10GbE
Data Transfer Rate
10 Gbps
Optical Wave Length
850 nm
200 m
Full duplex mode, Digital Diagnostics Monitoring (DDM)
1 x Ethernet 10GBase-SR - LC multi-mode female x 2
MTBF
498,745,585 hours
FCC, MSA
Brocade 10G-SFPP-SR
1 Watt
5.84 cm
1.39 cm
1.26 cm
20 g
Shipping Width
9 cm
Shipping Depth
11.5 cm
Shipping Height
3.1 cm
Shipping Weight
50 g
Limited warranty - lifetime
Type: Modules
