£19.22 ex VAT
£23.06 inc VAT
Turn your home stereo, or any audio output into a Bluetooth-compatible media gateway with this Bluetooth 5.0 audio receiver that features a Hi-Fi grade Wolfson WM8524 Digital to Analog Converter (DAC), and provides rich and high-quality sound.
  • Digital and Analog outputs
    This BT receiver lets you connect audio systems that have analog audio inputs (3.5mm jack) with the included 3.5mm to RCA cable. Alternatively, you can connect to newer audio systems via the Optical output to take advantage of lossless/high-resolution audio files.
  • Increased Transmission Range
    With Bluetooth 5.0 you can stream to longer distances up to 20m (66ft) of line of distance. Obstructions between the receiver and your mobile devices will decrease the transmission range.
  • Easy Pair up to 8 Devices
    This wireless Bluetooth receiver can hold up to 8 paired devices in memory, so your audio system is always ready to play music from your favorite devices (audio is streamed to one device at a time). With Near Field Communication (NFC), simply tap your NFC-equipped devices to the aux receiver to instantly pair and start streaming audio, with no additional configuration required. The BT52A is backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com Bluetooth 5.0 Audio Receiver with NFC, Bluetooth Wireless Audio Adapter BT 5.0, 66ft (20m) Range, 3.5mm/RCA or Digital Toslink/SPDIF Optical Output, Lossless HiFi Wolfson DAC - For Stereos/Speakers - Bluetooth wireless audio receiver
Wireless Interface
NFC, Bluetooth
Package Content
AC power adaptor, audio cable, 3.5 mm to RCAx2 adapter, Bluetooth wireless audio receiver
Product Material
Plastic
8.4 cm x 2.6 cm x 7.7 cm
Wireless Interface
NFC, Bluetooth 5.0
Supported Digital Audio Standards
Apt-X, SBC, apt-X HD, apt-X LL
Package Content
Product Material
Plastic
8.4 cm
2.6 cm
7.7 cm
Audio line-out - mini-phone stereo 3.5 mm , Digital audio output (optical) - TOS Link , USB - micro-USB
Power Source
USB
2 years , Technical support - lifetime
GWXB StarTech.com USB Bluetooth 5.0 Adapter In Stock £10.87
Device Type: All
Type: Audio Adapter
Product Range: StarTech.com
Product Model: Bluetooth 5.0 Audio Receiver with NFC, Bluetooth Wireless Audio Adapter BT 5.0, 66ft (20m) Range, 3.5mm/RCA or Digital Toslink/SPDIF Optical Output, Lossless HiFi Wolfson DAC - For Stereos/Speakers
