StarTech.com Black Aluminum 5.25in Rugged SATA Hard Drive Mobile Rack Drawer
Quicklinx: 76LTWS00 Mfr#: DRW150SATBK
Type: Storage mobile rack
HD Size: 3.5
Power Supply: None
£35.04 ex VAT
£42.04 inc VAT
Turns any 3.5in SATA hard drive into a rugged, hot-swap storage solution for a 5.25in bay. This high quality Removable SATA Hard Drive Drawer/Mobile Rack delivers a professional-grade hot-swap solution, allowing you to quickly swap SATA hard drives in/out of a computer without having to open the computer case. The mobile rack is fully compatible with RAID installations to ensure maximum performance and versatility for enhanced storage applications.
To maximize performance and utilize the full speed potential of your SATA III hard drives, this HDD Backplane supports SATA III for transfer speeds up to 6 Gbps when paired with compatible controller.
Simply install the drive bay into a 5.25in bay on the host computer, then mount a 3.5in SATA HDD into the (removable) caddy. Connecting the SATA hard drive to the computer is as easy as inserting the caddy into the drive bay, which can be locked to prevent unauthorized removal of the drive. Features a front panel ball bearing fan, aluminum construction and 25K insertion rating.
This product is interchangeable as a replacement for StorCase SATA models S21J111, SC21J111 and RJR110.
StarTech.com 5.25 in Rugged SATA Hard Drive Mobile Rack Drawer - Aluminum Removable Hard Drive Bay (DRW150SATBK) - storage mobile rack
Storage mobile rack
Expansion Bays
1 x internal - 3.5"
Compatible Bay
1 5.25" x 1/2H
Hard Drive Form Factor Compatibility
3.5"
Supported Interface
SATA 1.5Gb/s
Drive Connector
7 pin Serial ATA
Bay Connector
7 pin Serial ATA
Ball bearing cooling fan, data indicator, power indicator, key lock
Product Material
Plastic, aluminium
14.7 cm x 19 cm x 4.1 cm
1 kg
Storage mobile rack
3.5"
Product Material
Plastic, aluminium
Supported Interface
SATA 1.5Gb/s
Storage Controller
No CPU
Bays
1 x internal - 3.5"
1 storage - Serial ATA-150 - 7 pin Serial ATA
Compatible Bay
1 x external 5.25" x 1/2H
ISO 9001
14.7 cm
19 cm
4.1 cm
1 kg
HD Size: 3.5
Power Supply: None
