Add convenient A/V connectivity and network access to your boardroom, classroom or huddle space. This audio/video module makes it easy to connect HDMI, DisplayPort and VGA laptops to your room's HDMI display.
Modern office environments need to support technology more than ever, to keep laptops, phones and tablets connected. During meetings, lectures and conferences, you may need to present content from your laptop to a display or projector.
This A/V module simplifies connectivity and collaboration with automatic switching and conversion. It lets you connect your HDMI, DP or VGA laptop to a shared HDMI display or projector, without the hassle of menu and input selections. And, the module automatically switches to the most recently connected or powered-on laptop. Installing the module is easy, requiring just a single HDMI cable between the module and the display.
Architectural connectivity is quickly becoming the trend when designing a boardroom or huddle space. StarTech.com A/V modules let you: Customize A/V connectivity according to the specific needs of your space ; Install in easy to access locations .
You can install this A/V module as a standalone solution using the supplied table-mounting bracket. Or, you can install it as an accessory in a StarTech.com single-module (BEZ4MOD) or dual-module (BOX4MODULE) conference room table connectivity box (each sold separately).
Conveniently Connect to a Display
Modern office environments?need to support technology more than ever, to keep laptops, phones and tablets connected.?During?meetings, lectures and conferences, you may need?to present content from your laptop to a display or projector.? This?A/V module simplifies connectivity and collaboration with automatic switching and conversion. It lets you connect your HDMI, DP or VGA laptop to a shared HDMI display or projector, without the hassle of menu and input selections. And, the module automatically switches to the most recently connected or powered-on laptop. Installing the module is easy, requiring just a single HDMI cable between the module and the display. -
Customize to Your Exact Needs
Architectural connectivity is?quickly becoming the trend when designing a boardroom or huddle space.?StarTech.com A/V modules let you:? • Customize?A/V connectivity?according to the specific needs of your space? • Install?in easy to access locations? You can install this?A/V?module?as?a?standalone solution?using the supplied table-mounting bracket. Or,?you?can?install?it?as an accessory in a StarTech.com single-module (BEZ4MOD) or dual-module (BOX4MODULE) conference room table connectivity box (each sold separately). MOD4AVHD is backed by a StarTech.com 2-year warranty and free lifetime technical support.
- StarTech.com Audio / Video Module for Conference Table Connectivity Box - mounting plate
- Product Type
- Mounting plate - RJ-45, mini-phone 3.5mm, HDMI, DisplayPort, VGA
- Package Content
- Mounting bracket, external power adapter, 4 x M5 screws, 8 module screws
- 10.5 cm x 11 cm x 6 cm
- 200 g
- Product Material
- Plastic, aluminium
- Black
- Localisation
- North America, United Kingdom, Europe
- 2-year warranty
- Designed For
- P/N: BEZ4MOD, BOX4MODULE
- Product Type
- Mounting plate
- Package Content
- Product Material
- 10.5 cm
- 11 cm
- 6 cm
- 200 g
- Enclosure Colour
- Black
- Localisation
Cabling & Wiring
- Connector Provided
- 3 x 19 pin HDMI Type A female , 2 x 20 pin DisplayPort female , 2 x RJ-45 female , 1 x 15 pin HD D-Sub (HD-15) female , 3 x mini-phone stereo 3.5 mm female
- Shipping Weight
- 200 g
- Limited warranty - 2 years
- 0 °C
- 60 °C
- 10 - 85% (non-condensing)
- Designed For
StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £13.58 |
StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.37 |
StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.56 |
StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.97 |
StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad | In Stock | £14.23 |
StarTech.com 2m (6ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad | In Stock | £15.14 |
StarTech.com 3m (10ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad | In Stock | £17.97 |
StarTech.com 6 ft DisplayPort Cable with Latches - M/M | In Stock | £13.72 |
