This VESA TV Wall Mount supports TV displays from 26" to 65" and up to 99.2 lb (45kg). Robust steel and aluminum frame for a long-lasting TV installation. The arm assembly provides smooth motion and retracts towards the wall for low-profile configurations. In addition, the articulating TV wall mount features an array of adjustments for an ideal viewing angle and supports VESA patterns from 200x200 to 400 x400.
                Versatile TV MountingSecurely mount a flat or compatible curved-screen TV or digital signage for visitors, clients, and employees to view. This TV wall mount is ideal for lobbies, boardrooms, and manufacturing facilities. The lateral range of 3.1ft (95.6cm) is ideal for corner mounting, and the jointed arm folds on itself, creating a slim profile from the wall of just 4.1in (10.5cm) for limited-space installations. Mount the articulating TV wall mount to a single wood stud or a concrete wall using the included keyhole-style mounting plate for quick and hassle-free installation. In addition, M4/5/6/8 screws of various lengths, matching washers, and spacers enhance the TV mounting compatibility. Supported VESA mounting patterns: 200x200, 200x300, 200x400, 300x200, 300x300, 400x200, 400x300, and 400x400.
                Smooth Motion and Tidy InstallationCustomize the viewing experience and comfort with these adjustment capabilities. The TV mount can rotate +90/-90 degrees at the wall mount assembly plate, as well as at both pivot points, while the VESA vertical bracket can be tilted +15/-15 degrees. The arm assembly extends up to 22.1in (56.2cm) from the wall to accommodate different viewing positions, including corner mounting. Built-in cable management and a wall mount cover for an organized and visually appealing installation. This TAA corner TV mount is backed for five years, including free lifetime 24/5 multi-lingual technical assistance.
- StarTech.com Articulating TV Wall Mount, VESA Wall Mount Supports 65 inch/99lb/Flat/Curved TVs, Retractable Low Profile Wall Mount TV Bracket, Adjustable Corner TV Wall Mount, Swivel/Rotation/Tilt (TV-WALL-MOUNT-65FS) mounting kit - articulating - for curved / flat panel - low profile - black, silver - TAA Compliant
- Product Type
- Mounting kit (articulating) - wall-mountable
- Mounting Components
- Wall mount, 2 vertical brackets
- Integrated Devices
- Spirit level
- 50 cm x 45 cm x 10.5 cm
- Tilt
- -15° to 15°
- Rotation
- -90° to 90°
- Swivel
- 180°
- Adjustments
- Tilt, swivel, rotation
- 7.8 kg
- Recommended Use
- Curved / flat panel
- Recommended Display Size
- 26"-65"
- VESA Mounting Interface
- 200 x 100 mm, 200 x 200 mm, 200 x 300 mm, 200 x 400 mm, 300 x 200 mm, 300 x 300 mm, 400 x 200 mm, 400 x 300 mm, 400 x 400 mm
- Max Load Weight
- 45 kg
- Material
- Aluminium, steel
- Black, silver
- TAA Compliant
- Package Content
- Hex key (6mm), 2 x vertical bracket screws, 8 wall mounting screws, 8 x concrete anchors, 4 x flat washers, 4 x M4 x 12 mm screws, 4 x M4 x 18 mm screws, 4 x M5 x 12 mm screws, 4 x M6 x 12 mm screws, 4 x M6 x 18 mm screws, 4 x M8 x 18 mm screws, 4 x M8x 12 mm screws, mounting template
- 5-year warranty
- 50 cm
- 45 cm
- 10.5 cm
- 7.8 kg
- Material
- Aluminium, steel
- Black, silver
- Package Content
AV Furniture
- Mounting kit
- Design
- Articulating
- Recommended Use
- Placing / Mounting
- Wall-mountable
- Spirit level
- Cable Management
- Integrated cable management
- 26"-65"
- Tilt
- -15° to 15°
- Rotation
- -90° to 90°
- Swivel
- 180°
- Adjustments
- Max Load Weight
- 45 kg
- TAA Compliant
Dimensions & Weight Details
- Dimensions
- Adjustable mounting arm (minimum) - depth: 10.5 cm , Adjustable mounting arm (maximum) - depth: 56.2 cm
- Shipping Dimensions (WxDxH) / Weight
- 62.4 cm x 46 cm x 12.4 cm / 9.2 kg
- Limited warranty - 5 years , Technical support - assistance - lifetime
