StarTech.com Arista Networks SFP-1G-LX Comp SFP SM Module - 1000Base-LX
Quicklinx: FHHBWS00 Mfr#: AR-SFP-1G-LX-ST
Type: Transceiver
£23.40 ex VAT
£28.08 inc VAT
The AR-SFP-1G-LX-ST is an Arista Networks SFP-1G-LX compatible fiber transceiver module that has been designed, programmed and tested to work with Arista Networks brand switches and routers. It delivers dependable 1 GbE connectivity over fiber cable, for 1000Base-LX compliant networks, with a maximum distance of up to 10 km (6.2 mi).
This SFP fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com Arista Networks SFP-1G-LX Compatible SFP Module, 1000BASE-LX, 1GbE Single Mode (SMF) Fiber SMF Optic Transceiver, 1GE Gigabit Ethernet SFP, LC Connector, 10km, 1310nm, DDM - Lifetime Warranty (AR-SFP-1G-LX-ST) - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - LC single-mode
Plug-in module
Cabling Type
1000Base-LX
Data Transfer Rate
1 Gbps
Optical Wave Length
1310 nm
1GbE
Max Transfer Distance
10 km
5.66 cm x 1.37 cm x 1.25 cm
18 g
Plug-in module
Wired
Cabling Type
1000Base-LX
1GbE
Data Transfer Rate
1 Gbps
Optical Wave Length
1310 nm
10 km
Digital Diagnostics Monitoring (DDM)
1 x Ethernet 1000Base-LX - LC single-mode female x 2
MTBF
634,210,013 hours
FCC, MSA
1.3 Watt
5.66 cm
1.37 cm
1.25 cm
18 g
Shipping Width
9 cm
Shipping Depth
11.5 cm
Shipping Height
3.1 cm
Shipping Weight
50 g
Limited warranty - lifetime
Type: Transceiver
