StarTech.com Arista Networks QSFP-40G-XSR4 Comp QSFP+ MM Module - 40GBase
Quicklinx: FJNFWS00 Mfr#: QSFP-40G-XSR4-AR-ST
£32.43 ex VAT
£38.91 inc VAT
The QSFP-40G-XSR4-AR-ST is an Arista QSFP-40G-XSR4 compatible fiber transceiver module that has been designed, programmed and tested to work with Arista brand switches and routers. It delivers dependable 40 GbE connectivity over fiber cable, for 40GBase-SR4 compliant networks, with a maximum distance of up to 400 m (1312 ft.).
This SFP fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com Arista Networks QSFP-40G-XSR4 Compatible QSFP+ Module, 40GBASE-SR4, 40GbE Multimode Fiber MMF Optic Transceiver, 40GE Gigabit Ethernet QSFP+, MPO Connector, 400m, 850nm, DDM - Lifetime Warranty (QSFP-40G-XSR4-AR-ST) - QSFP+ transceiver module - 40GbE
QSFP+ transceiver module - MPO multi-mode
Plug-in module
Cabling Type
40GBASE-SR4
Data Transfer Rate
40 Gbps
Optical Wave Length
850 nm
40GbE
Max Transfer Distance
400 m
12.2 cm x 1.86 cm x 0.85 cm
37.5 g
Plug-in module
Wired
Cabling Type
40GBASE-SR4
40GbE
Data Transfer Rate
40 Gbps
Optical Wave Length
850 nm
400 m
Digital Diagnostics Monitoring (DDM)
1 x Ethernet 40GBASE-SR4 - MPO multi-mode female
MTBF
244,610,583 hours
FCC, MSA
12.2 cm
1.86 cm
0.85 cm
37.5 g
Shipping Width
9.2 cm
Shipping Depth
11.7 cm
Shipping Height
3.4 cm
Shipping Weight
75 g
Limited warranty - lifetime
