Work in greater comfort with this large anti-fatigue mat for standing desks or sit-stand workstations. It provides a durable cushioned surface to help reduce strain, plus a large surface area for versatile use.
COMFORTABLE & DURABLE: Designed with thick polyurethane foam (typically found in carpet underlay) this anti-fatigue mat for standing desk provides additional thickness to ensure comfort and durability.
EASY TO CLEAN: Cushioned stand-up desk pad is easy to clean and maintain by simply wiping it down to keep the mat free of stains, dust, dirt and other debris.
THOUGHTFUL DESIGN: Textured rubber anti-slip bottom helps prevent the mat from sliding on vinyl/tile floors; The beveled edges & rounded corners provide a level of safety by reducing tripping.
Please note: the anti-fatigue mat is not intended for use with high heels, which may cause damage to the mat surface.
- StarTech.com Anti-Fatigue Mat for Standing Desk, Ergonomic Mat for Standing Desk, Large 24" x 36" Surface, Non-Slip, Cushioned Comfort Floor Pad for Sit Stand/Stand Up Office/Work Desk - Standing Desk Pad Mat (STSMATL) - floor mat - rectangular - 91 x 61 cm - black
- Product Type
- Floor mat - rectangular
- Size
- 91 x 61 cm
- Anti-Slip
- Black
- Material
- Polyurethane
- 2 years
- Designed For
- P/N: LAPTOP-SIT-STAND, SECTBLTPOS, STNDTBLT1A5T, STNDTBLT1FS
- Product Type
- Floor mat
- Shape
- Rectangular
- Size
- 91 x 61 cm
- Black
- Material
- Polyurethane
- Bevelled edge
- Warranty
- 2 years
Mat
- Anti-Slip
- Anti-fatigue
- 91 cm
- 61 cm
- 1.9 cm
- 2.2 kg
- Shipping Weight
- 2.7 kg
- Designed For
