Seamlessly incorporate a tablet into a workspace using this ergonomic adjustable tablet stand. Change tablet's position within the clamp to an angle that caters to the user's viewing needs. The stand for tablets features anti-slip pads on the clamp and underneath the base to protect the device and the working surface. Mount the base onto a desk using the included 4.2x19mm wood screws. The clamp supports tablets that feature a width of 5 to 8.8in (12.8 to 22.4cm) wide, 0.4in (1.0cm) thick, and a maximum weight of 2.2lb (1kg). The tablet stand holder ships fully assembled for quick deployment into customer-facing environments and Point-of-Sale applications.
Adjust the Viewing Angle
The jointed arm allows to adjust the height up to 18.5in (47cm) from the base and allows for various angle adjustments. The adjustable ball joint located at the end of the arm enables +/-52° swivel and 360° rotation for horizontal/vertical viewing. The elbow behind the ball joint provides +210° / -60° of tilt. The design of the Clamp does not block the ports, front-facing camera, or buttons, allowing users to take advantage of the features of a tablet. -
Hassle-Free Deployment
The stand for tablets ships fully assembled for fast implementation and requires little to no setup for minimum downtime. The base features mounting holes for desk or wall installation (wood screws included). When the device's safety is a concern, the optional parts KSLTAD and LTLOCK3DCOIL (sold separately) provide anti-theft protection. Use this tablet stand to effortlessly integrate a tablet on POS kiosks, retail, classrooms, hospitality services, boardrooms, food delivery services, and inventory sign-off. -
Compatibility
The Tablet Holder is compatible with iPads such as the 10.2" iPad, 11" and 12.9" iPad Pro, 10.9" iPad Air, 7.9" iPad mini, Samsung Galaxy Tab S9, and other tablets. The Adjustable Tablet Stand is backed for five years, including free lifetime 24/5 multi-lingual technical assistance.
- StarTech.com Adjustable Tablet Stand for Desk, Desk/Wall Mountable, Supports Up to 2.2lb, Universal Tablet Stand Holder for Desk, Articulating Tablet Mount with Pivot/Swivel/Rotate - Ergonomic Tablet Stand (ADJ-TABLET-STAND-W) stand - for tablet - white
- Product Type
- Stand - wall-mountable, desk-mountable
- 16 cm x 16 cm x 47 cm
- Adjustable Height
- 47 cm
- Tilt
- -52° to 52°
- Rotation
- 360°
- Swivel
- -5° to 185° (at base) / -100° to 90° (elbow)
- Adjustments
- Height, tilt
- 1.5 kg
- Recommended Use
- Tablet
- Recommended Display Size
- 4.7"-12.9"
- Max Load Weight
- 1 kg
- Material
- Aluminium and steel
- White
- Package Content
- 4 x 4.2x19 mm wood screw, hex key (5mm), hex key (3mm), quick start guide
- 5-year warranty
- 16 cm
- 16 cm
- 47 cm
- Adjustable Height
- 47 cm
- 1.5 kg
- Material
- White
- Package Content
AV Furniture
- Stand
- Recommended Use
- Tablet
- Placing / Mounting
- Wall-mountable, desk-mountable
- 4.7"-12.9"
- Tilt
- -52° to 52°
- Rotation
- 360°
- Swivel
- Adjustments
- Height, tilt
- Max Load Weight
- 1 kg
- Details
- Portrait orientation, landscape orientation
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
- 30.5 cm x 17.3 cm x 11.6 cm
- Limited warranty - 5 years
StarTech.com Lightning/Micro USB Cable | In Stock | £16.51 |
StarTech.com Laptop Cable Lock - Self-Coiling Cable - 3-Digit Combination | In Stock | £17.93 |
StarTech.com 1 m / 3.3 ft USB 2.0 to USB C Cable – Black | In Stock | £9.14 |
StarTech.com Slim Anti-Theft K-Slot Lock Plate Adapter for MacBook/Tablet/iPad/Phone/Laptop | In Stock | £7.60 |
