StarTech.com Adjustable Tablet Stand
Quicklinx: H2Z0WS00 Mfr#: ADJ-TABLET-STAND-W
Device Type: Tablet
Type: Tablet Stand
Device Screen Size: 4.7 - 12.9
Colour: White
20 In Stock
£28.89 ex VAT
£34.66 inc VAT
Seamlessly incorporate a tablet into a workspace using this ergonomic adjustable tablet stand. Change tablet's position within the clamp to an angle that caters to the user's viewing needs. The stand for tablets features anti-slip pads on the clamp and underneath the base to protect the device and the working surface. Mount the base onto a desk using the included 4.2x19mm wood screws. The clamp supports tablets that feature a width of 5 to 8.8in (12.8 to 22.4cm) wide, 0.4in (1.0cm) thick, and a maximum weight of 2.2lb (1kg). The tablet stand holder ships fully assembled for quick deployment into customer-facing environments and Point-of-Sale applications.
  • Adjust the Viewing Angle
    The jointed arm allows to adjust the height up to 18.5in (47cm) from the base and allows for various angle adjustments. The adjustable ball joint located at the end of the arm enables +/-52° swivel and 360° rotation for horizontal/vertical viewing. The elbow behind the ball joint provides +210° / -60° of tilt. The design of the Clamp does not block the ports, front-facing camera, or buttons, allowing users to take advantage of the features of a tablet.
  • Hassle-Free Deployment
    The stand for tablets ships fully assembled for fast implementation and requires little to no setup for minimum downtime. The base features mounting holes for desk or wall installation (wood screws included). When the device's safety is a concern, the optional parts KSLTAD and LTLOCK3DCOIL (sold separately) provide anti-theft protection. Use this tablet stand to effortlessly integrate a tablet on POS kiosks, retail, classrooms, hospitality services, boardrooms, food delivery services, and inventory sign-off.
  • Compatibility
    The Tablet Holder is compatible with iPads such as the 10.2" iPad, 11" and 12.9" iPad Pro, 10.9" iPad Air, 7.9" iPad mini, Samsung Galaxy Tab S9, and other tablets. The Adjustable Tablet Stand is backed for five years, including free lifetime 24/5 multi-lingual technical assistance.
StarTech.com Adjustable Tablet Stand for Desk, Desk/Wall Mountable, Supports Up to 2.2lb, Universal Tablet Stand Holder for Desk, Articulating Tablet Mount with Pivot/Swivel/Rotate - Ergonomic Tablet Stand (ADJ-TABLET-STAND-W) stand - for tablet - white
Stand - wall-mountable, desk-mountable
16 cm x 16 cm x 47 cm
Adjustable Height
47 cm
Tilt
-52° to 52°
Rotation
360°
Swivel
-5° to 185° (at base) / -100° to 90° (elbow)
Adjustments
Height, tilt
1.5 kg
Recommended Use
Tablet
Recommended Display Size
4.7"-12.9"
Max Load Weight
1 kg
Material
Aluminium and steel
White
Package Content
4 x 4.2x19 mm wood screw, hex key (5mm), hex key (3mm), quick start guide
5-year warranty
16 cm
16 cm
47 cm
Adjustable Height
47 cm
1.5 kg
Material
Aluminium and steel
White
Package Content
AV Furniture
Stand
Recommended Use
Tablet
Placing / Mounting
Wall-mountable, desk-mountable
4.7"-12.9"
Tilt
-52° to 52°
Rotation
360°
Swivel
Adjustments
Height, tilt
Max Load Weight
1 kg
Details
Portrait orientation, landscape orientation
Dimensions & Weight Details
30.5 cm x 17.3 cm x 11.6 cm
Limited warranty - 5 years
H2Z0 StarTech.com Laptop Cable Lock - Self-Coiling Cable - 3-Digit Combination In Stock £16.14
H2Z0 StarTech.com 1 m / 3.3 ft USB 2.0 to USB C Cable – Black In Stock £9.33
H2Z0 StarTech.com Slim Anti-Theft K-Slot Lock Plate Adapter for MacBook/Tablet/iPad/Phone/Laptop In Stock £7.52
Device Type: Tablet
Type: Tablet Stand
Colour: White
