StarTech.com Adjustable CPU Wall Mount
Quicklinx: D5BJWS00 Mfr#: CPUWALLMNT
Accessory Type: Wall Mount
35 In Stock
£33.33 ex VAT
£39.99 inc VAT
Maximize your work space by wall-mounting your CPU for easy access. This adjustable CPU mount is an excellent solution both to save space and extend the life of your equipment. Hanging your computer tower on the wall can help to reduce internal contamination from dust and dirt.
This computer wall mount frees up your floor and desk space, so that you can focus on what's important. The heavy-duty black metal frame is strong and dependable, ensuring your computer is securely fastened.
The adjustable base on the CPU wall mount makes it easy to fit a variety of computers, from 4.8" to 8.3" (122 to 212 mm) in width,. It can hold up to 22 lb. (10 kg). The adjustable straps will ensure your computer is secure.
The open frame design of the CPU mount allows unrestricted access to your computer.
Get up and running quickly. The CPU wall mount is easy to mount, and it comes with all the required hardware and an instruction manual to make installation simple. It mounts easily to walls or other sturdy vertical surfaces.
  • Adjustable design
    The adjustable width feature allows the holder to accommodate various CPU sizes, ensuring a snug fit and maximizing space efficiency.
  • Durable construction
    Built from robust steel, this CPU holder supports a weight of up to 10 kg, providing security for your valuable equipment.
  • Space-saving solution
    The wall-mountable design elevates the computer off the floor, reducing clutter and enhancing the aesthetics of your workspace.
StarTech.com Wall Mount CPU Holder - Adjustable Width 4.8in to 8.3in - Metal - Computer Tower Mounting Bracket for Desktop PC (CPUWALLMNT) bracket - for CPU - black
Bracket - wall-mountable
21.2 cm x 23.5 cm x 15.4 cm
Adjustments
2.2 kg
Recommended Use
CPU
Max Load Weight
10 kg
Material
Steel
5-year warranty
P/N: WALLSTS1, WALLSTS2
21.2 cm
23.5 cm
15.4 cm
2.2 kg
Material
Steel
AV Furniture
Bracket
Recommended Use
CPU
Placing / Mounting
Wall-mountable
Adjustments
Max Load Weight
10 kg
Limited warranty - 5 years
D5BJ StarTech.com Thin Client Mount - VESA In Stock £23.04
D5BJ StarTech.com Computer Tower Cart, Rolling In Stock £31.64
