Route this Ultra High Speed HDMI 2.1 Hybrid Active Optical Cable (AOC) through office plenum spaces for long distance transmission of 8K 60Hz video and high quality audio.
Hybrid AOC Construction
The HDMI 2.1 AOC features a hybrid construction consisting of fiber optic cores and copper conductors. This enables the offloading of low-bandwidth signals (EDID/HDCP/eARC) to maintain high-bandwidth transmission of 8K 60Hz video over fiber. The fiber optic inner cores and shielded copper conductors greatly reduce EMI for optimal signal quality across longer distances. -
Full-Featured HDMI 2.1
The 8K HDMI Fiber Optic Cable supports full HDMI 2.1 specifications: • High Bit Rate 3 (HBR3) supports up to 48Gbps bandwidth for higher refresh rates • High Dynamic Range (HDR10+) with 12-bit processing for higher contrast ratio and vibrant, cinematic picture quality • Enhanced Audio Return Channel (eARC) for uncompressed 7.1 and 32-channel audio • Display Stream Compression 1.2a (DSC) for maximum resolution output • Forward Error Correction to manage data transmission errors • High-Bandwidth Digital Content Protection (HDCP 2.3) for a secure connection between source and display -
Flexible Plenum-Rated Cabling
This Plenum-Rated HDMI 2.1 Cable features a CMP-rated cable jacket with low-smoke and flame characteristics. It is ideal for use in plenum spaces in buildings (e.g., ceilings and in-wall installations). The optical fiber core is reinforced with Aramid strands for tensile strength, and is rated to withstand over 6,000 bending cycles at 120 degrees. This protects the cable from damage when routing through tight spaces requiring multiple bends. The 4.6mm (0.18in) cable outer diameter is flexible and slimmer than typical passive HDMI cables, making it suitable for installation in space-constrained environments. Please Note : This cable is unidirectional and must be installed in a specific direction. Please refer to the SOURCE and DISPLAY labels on the HDMI connectors to ensure that each end corresponds with the correct hardware.
 - StarTech.com 50ft (15.2m) HDMI 2.1 Hybrid Active Optical Cable (AOC), CMP, Plenum Rated, 8K Ultra High Speed HDMI Fiber Optic Cable, 48Gbps, 8K 60Hz/4K 120Hz, HDR10+/FRL/TMDS/eARC - CMP In Wall HDMI 2.1/2.0 Cord (8K-A-50F-HDMI-CABLE) - HDMI cable - 15.2 m
- Cable
 - Ultra High Speed - HDMI cable
- Technology
 - Hybrid copper/fibre optic
- American Wire Gauge (AWG)
 - 28/30
- Length
 - 15.2 m
 - Black
- Connector
 - HDMI - male
- Connector (Second End)
 - HDMI - male
 - Active Optical Cable (AOC), 4K120Hz support, 8K60Hz support, 4K60Hz support
 - 2-year warranty
- Cable Type
 - Ultra High Speed - HDMI cable Active Optical Cable (AOC), 4K120Hz support, 8K60Hz support, 4K60Hz support
- Technology
 - 28/30
- Jacket Material
 - PVC
- Shielding Material
 - Aluminium-polyester foil
- Length
 - 15.2 m
- Plated Connector
 - Gold
 - Enhanced Audio Return Channel (eARC), HBR3 audio support, HDR 10+ support, Display Stream Compression (DSC) 1.2a, HDCP, 32 audio channels, plenum cable, bus powered, zinc alloy housing, outer diameter 4.6 mm, bandwidth of 48 Gbps, 7.1 audio channel support (HDMI)
 - Black
- Connector
 - 19 pin HDMI Type A - male
 - HDCP 2.3
- Shipping Width
 - 23.5 cm
- Shipping Depth
 - 22 cm
- Shipping Height
 - 3.8 cm
- Shipping Weight
 - 900 g
 - Limited warranty - 2 years
                        StarTech.com 2-Port 8K 60Hz HDMI Switch | In Stock | £43.06 |
                        StarTech.com 8K HDMI Switch, 8K 60Hz | In Stock | £62.43 |
                        StarTech.com 8K 60Hz HDMI Signal Booster | In Stock | £77.10 |
                        StarTech.com USB-C KVM Switch, 4K 60Hz | In Stock | £146.60 |
                        StarTech.com Active Optical HDMI 2.1 Cable 100ft | In Stock | £207.42 |
                        StarTech.com Active Optical HDMI 2.1 Cable 30ft | In Stock | £141.74 |
                        StarTech.com Active HDMI 2.0 Cable | In Stock | £142.66 |
                        StarTech.com Active HDMI 2.0 Cable | In Stock | £172.58 |
