StarTech.com Active High Speed HDMI Cable 10m
Quicklinx: J4KXWS00 Mfr#: HDMI2-CABLE-4K60-10M
More than 50 In Stock
£38.29 ex VAT
£45.94 inc VAT
Connect to a 4K UHD TV or monitor, using this HDMI 2.0 Cable. The connector markings enable quick visual identification, distinguishing this cable from other similar-looking or unmarked HDMI cables. Eliminate guesswork and always choose the appropriate cable to support full HDMI 2.0 with Ethernet capabilities.
The Active HDMI 2.0 cord is designed for long-distance reliability. Durable gold-plated connectors and 24AWG bare copper wire maintain optimal conductivity and low resistance, ensuring consistent performance across different environments. The integrated active chipset boosts the HDMI signal without requiring external power, facilitating 4K 60Hz video and full HDMI 2.0 capabilities. This enables the transmission of HDMI UHD video beyond passive cable lengths. For seamless operation between HDMI-enabled devices, the HDMI 2.0 cable is designed for guaranteed HDMI 2.0 performance and backward compatibility. This High Speed HDMI Cable features a flexible TPE outer jacket that is tested to withstand 2,000 bending cycles at -/+60 degrees, and routes easily around corners and desk edges. Robust strain reliefs enable convenient positioning of the cable. The durable Gold-plated connectors are rated to operate beyond 10,000 insertions. This HDMI Cable supports full HDMI 2.0 features, including resolutions up to 4K 60Hz using a compatible HDMI source and display, high refresh rates including 1440p 144Hz and 1080p 240Hz, 21:9 Aspect Ratio, High Dynamic Range (HDR10) for higher contrast ratio, High-Bandwidth Digital Content Protection (HDCP) 2.2 for a secure connection between source and display, Audio Return Channel (ARC), Up to 32 Uncompressed Digital Audio Channels, HDMI Ethernet Channel (HEC) for network connectivity over HDMI, and backward compatible with previous HDMI versions. This HDMI 2.0 Cable is constructed with braided aluminum mylar shielding to minimize EMI for clear, consistent audio/video output and long-term reliable performance.
  • HDMI UHD Over Long Distances
  • Durable Design
  • Supported HDMI 2.0 Features:
    This HDMI Cable supports full HDMI 2.0 features: • Resolutions up to 4K 60Hz using a compatible HDMI source and display • Supports high refresh rates including 1440p 144Hz and 1080p 240Hz • 21:9 Aspect Ratio support for cinematic viewing experiences • High Dynamic Range (HDR10) for higher contrast ratio and vibrant picture quality • High-Bandwidth Digital Content Protection (HDCP) 2.2 for a secure connection between source and display • Audio Return Channel (ARC) for sending audio from the TV back to an AV receiver or soundbar • Up to 32 Uncompressed Digital Audio Channels • HDMI Ethernet Channel (HEC) for network connectivity over HDMI • Backward compatible with previous HDMI versions This HDMI 2.0 Cord is constructed with braided aluminum mylar shielding to minimize EMI for clear, consistent audio/video output and long-term reliable performance.
StarTech.com 10m (32.8ft) Active High Speed HDMI Cable, 4K60Hz - HDMI cable with Ethernet - 10 m
Cable
High Speed - HDMI cable with Ethernet
Shielded
American Wire Gauge (AWG)
24
Length
10 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
Active cable, 4K60Hz UHD support, 2K144Hz support, HDR10 support
Cable Type
High Speed - HDMI cable with Ethernet active, 4K60Hz UHD support, 2K144Hz support, HDR10 support
Shielded
24
Jacket Material
Thermoplastic elastomer (TPE)
Shielding Material
Length
10 m
Plated Connector
Gold
18 Gbps data rate, Audio Return Channel (ARC), HDMI Ethernet Channel (HEC), HDMI CEC support (Consumer Electronics Control), 4k(2160p)@60Hz / 1440p@144Hz / 1080p@240Hz, 32 audio channels, 10000 insertions lifespan, 2000 bend lifespan, outer diameter 9 mm, marked connectors, strain relief, halogen free, EMI protection, 21:9 cinema aspect ratio, 12 Bit Deep Colour, 7.1 channel Surround Sound
Connector
19 pin HDMI Type A - male
HDCP 2.2, RoHS, WEEE
Shipping Width
34.7 cm
Shipping Depth
46 cm
Shipping Height
4.4 cm
Shipping Weight
800 g
Limited warranty - lifetime
