StarTech.com Active HDMI 2.0 Cable
Quicklinx: HSTCWS00 Mfr#: HD2AP-10M-HDMI-CABLE
Length: 10m
Hurry, only 1 left in stock!
£142.66 ex VAT
£171.19 inc VAT
The Active HDMI 2.0 cord is designed for long-distance reliability. Durable gold-plated connectors and 24/28 AWG bare copper wire maintain optimal conductivity and low resistance, ensuring consistent performance across different environments. The integrated active chipset boosts the HDMI signal without requiring external power, facilitating 4K 60 Hz video and full HDMI 2.0 capabilities. This enables the transmission of HDMI UHD video beyond passive cable lengths.
  • Designed for long range
    The active HDMI 2.0 cable delivers 4K 60 Hz beyond the length of passive copper cables. An integrated active chipset enables consistent performance without requiring an external booster or power source.
  • Plenum rated
    CMP-rated active HDMI cable jackets are designed for safe installation in plenum spaces. They are suitable for runs in ceilings, conduits, and walls. These cables are intended for use in commercial environments and comply with fire codes.
  • Wide application
    Full-featured HDMI 2.0 enables dynamic HDR10 10-bit processing, providing vibrant picture quality. It is ideal for UHD/4K monitors, projectors, large displays, conference rooms, and video walls. It supports 7.1 and 32-channel audio with ARC and is compatible with HDMI 1.4/1.2.
  • Quality construction
    Gold-plated connectors are rated for over 10,000 insertion cycles. They have a durable plenum jacket with sturdy strain reliefs. They have been tested for over 1,000 bending cycles at -/+ 60°.
StarTech.com 10m Active HDMI 2.0 Cable, CMP, Plenum Rated, 4K 60Hz - HDMI cable - 10 m
Cable
High Speed - HDMI cable
Shielded
American Wire Gauge (AWG)
24/28
Length
10 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
Rated Current
300 mA
Active cable, Unidirectional, 4K60Hz support, HDR10 support
Cable Type
High Speed - HDMI cable active, Unidirectional, 4K60Hz support, HDR10 support
Shielded
24/28
Rated Current
300 mA
Jacket Material
PVC
Shielding Material
Length
10 m
Plated Connector
Gold
Recommended Use
Projector, monitor, display
Audio Return Channel (ARC), Variable Refresh Rate (VRR), strain relief, 32 audio channels, plenum cable, 10 bit deep colour, outer diameter 9mm, bus powered, Spectra HT8181 chipset, bare copper conductor, 7.1 channel Surround Sound, bandwidth of 18 Gbps, 10000 insertions lifespan, 1000 bend lifespan
Connector
19 pin HDMI Type A - male
RoHS, WEEE, RCM, HDCP 2.2, CMP
Shipping Width
25 cm
Shipping Depth
25 cm
Shipping Height
3.5 cm
Shipping Weight
1 kg
Limited warranty - lifetime
HSTC StarTech.com 4-Port HDMI Switch - 4K In Stock £36.90
HSTC StarTech.com 2-Port HDMI Switch - 4K In Stock £30.51
HSTC StarTech.com Conference Table Box w/Docking In Stock £180.80
HSTC StarTech.com Active HDMI 2.0 Cable In Stock £172.58
Length: 10m
