StarTech.com 9U Wall-Mount Rack Cabinet
Quicklinx: CZDGWS00 Mfr#: RK920WALM
Width (mm): 60cm
Depth (mm): 55cm
14 In Stock
£193.99 ex VAT
£232.78 inc VAT
Use this wall mount network cabinet to mount your server or networking equipment to the wall. This 9U server or network rack cabinet lets you mount your EIA-310 compliant equipment to the wall, in a secure enclosure. The enclosure features adjustable mounting depth from 3 to 20.8 in. to provide a robust storage solution for your rack-mount equipment.
To provide secure stability for your heaviest equipment, this rack offers 4-post mounting, supporting a higher weight capacity per U than 2-post racks and supporting a total load capacity of up to 200 lb. (90 kg).
Save valuable floor space, by wall-mounting the enclosure. The wall-mounted design makes this enclosure the ideal solution for optimizing equipment storage in your classroom, retail store, server room or office. This rack also includes a 1U shelf that gives you a stable surface for storing your tools placing equipment that's not rack-mountable.
The wall-mount network rack makes it easy to install your equipment, with cage nuts and mounting screws included. The rack includes all of the hardware you need to mount your equipment in the rack, saving you the time, hassle and cost of sourcing mounting hardware. The 9U network cabinet features a removable and reversible front door and removable side panels, each with quick-release mechanisms, so you can easily access your equipment. Plus, each door and panel on this rack features an independent lock, ensuring your equipment is secure.
For hassle-free cable management, the rack includes a 3-meter roll of hook-and-loop cable tie that makes it easy to keep your cables neat and tidy by binding them together or binding them to the rack. The self-gripping fabric can be cut to any size, enabling a wrap-around solution for the cables of any rack-mount equipment.
This server rack enclosure features heavy-duty steel construction, with lockable doors at all entrances. For hassle-free equipment installation, the mounting rails on the rack can be switched for use with square holes and cage nuts, or tapped rails.
To ensure your equipment is running at an optimal temperature, the server rack/cabinet promotes passive cooling. It features mesh doors and vented top and bottom panels for maximum airflow.
For simple and sturdy mounting, the rack's mounting holes are positioned 16 in. apart, so you can securely attach it to a wall using wall studs.
  • Save space in your office or server room
  • Easily install your servers and network equipment
    The wall-mount network rack makes it easy to install your equipment, with cage nuts and mounting screws included. The rack includes all of the hardware you need to mount your equipment in the rack, saving you the time, hassle and cost of sourcing mounting hardware. The 9U network cabinet features a removable and reversible front door and removable side panels, each with quick-release mechanisms, so you can easily access your equipment. Plus, each door and panel on this rack features an independent lock, ensuring your equipment is secure. For hassle-free cable management, the rack includes a 3-meter roll of hook-and-loop cable tie that makes it easy to keep your cables neat and tidy by binding them together or binding them to the rack. The self-gripping fabric can be cut to any size, enabling a wrap-around solution for the cables of any rack-mount equipment.
  • Securely protect your equipment
    This server rack enclosure features heavy-duty steel construction, with lockable doors at all entrances. For hassle-free equipment installation, the mounting rails on the rack can be switched for use with square holes and cage nuts, or tapped rails. To ensure your equipment is running at an optimal temperature, the server rack/cabinet promotes passive cooling. It features mesh doors and vented top and bottom panels for maximum airflow. For simple and sturdy mounting, the rack's mounting holes are positioned 16 in. apart, so you can securely attach it to a wall using wall studs. The RK920WALM is backed by a StarTech.com 5-year warranty and free lifetime technical support.
StarTech.com "9U Wall Mount Server Rack Cabinet - 4-Post Adjustable Depth (2"" to 19"") Network Equipment Enclosure with Cable Management (RK920WALM)" - rack enclosure cabinet - 9U
Rack enclosure cabinet
Placing / Mounting
Wall mountable
Package Content
2 side panel keys, 2 door keys, 36 screws (12-24), roll of hook-and-loop fastener, 36 cage nuts
Height (Rack Units)
9U
Product Material
Steel
60 cm x 55 cm x 50.4 cm
18 kg
Lockable front door, key lock, adjustable depth, hinged, mesh front door
5-year warranty
Placing / Mounting
Wall mountable
Product Material
Steel
Package Content
Height (Rack Units)
9U
60 cm
55 cm
50.4 cm
18 kg
Inner Dimensions
45 cm x 43 cm x 40 cm
Weight Limit
90 kg
Limited warranty: - 5 years
CZDG StarTech.com 8U Open Frame Wall Mount Equipment Rack - 12in Deep In Stock £71.35
CZDG StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £12.34
CZDG StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £30.51
CZDG StarTech.com Black Standard Universal Server Rack Cabinet Shelf In Stock £31.10
CZDG StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £14.45
CZDG StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £28.56
CZDG StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £54.09
CZDG StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £57.23
CZDG StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel In Stock £33.04
CZDG StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x3.9in (5.7x10cm) In Stock £3.06
CZDG StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) In Stock £4.40
CZDG StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) In Stock £6.45
CZDG StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel In Stock £39.94
CZDG StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £46.00
CZDG StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £17.96
CZDG StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £23.35
CZDG StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £57.09
CZDG StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £30.44
CZDG StarTech.com 100 Pkg M5 Cage Nuts In Stock £26.80
CZDG StarTech.com 50 Pkg M6 Cage Nuts In Stock £20.46
CZDG StarTech.com 100 Pkg M5 Cage Nuts In Stock £28.99
CZDG StarTech.com 50 Pkg M5 Cage Nuts In Stock £15.59
CZDG StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £54.01
CZDG StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £29.06
CZDG StarTech.com 50 Pkg M5 Mounting Screws In Stock £16.04
CZDG StarTech.com 100 Pkg M5 Mounting Screws In Stock £29.99
CZDG StarTech.com 50 Pkg M6 Mounting Screws In Stock £16.75
CZDG StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.29
CZDG StarTech.com 100 Pkg M6 Cage Nuts In Stock £28.49
CZDG StarTech.com 19in Cable Management Panel In Stock £23.30
CZDG StarTech.com 6U Wall-Mount Rack Cabinet In Stock £148.99
CZDG StarTech.com M6 Mounting Screws 50Pack In Stock £16.78
Width (mm): 60cm
Depth (mm): 55cm
