StarTech.com 9U Wall-Mount Rack - Open Frame - 2 Post - 18 in. Deep
Quicklinx: FP9SWS00 Mfr#: RK919WALLO
Hurry, only 2 left in stock!
£148.17 ex VAT
£177.80 inc VAT
2 Post Data Rack EIA 310 Compliant Steel Black. This open-frame 9u wall mount rack provides 9U of storage, allowing you to save space and stay organized. The 19 inch equipment rack can hold up to 175 lb. (80 kg).
Easy, Hassle-Free Installation
The wall mount open frame rack is 18 in. (45.7 cm) deep, so it's perfect for smaller spaces. It's easy to assemble and features mounting holes that are spaced 16 in. apart, making it suitable for mounting on almost any wall, based on common wall-frame stud spacing.
Free Up Space
You can mount the wall mount open frame rack where space is limited, such as on a server room wall, office, or above a doorway, to expand your workspace and ensure your equipment is easy to access.
Keep Your Equipment Cool and Accessible
By having an open frame, the small wall mount network rack provides passive cooling to equipment. Additionally, the open frame provides easy access and configurability to your equipment, allowing you to maximize productivity.
The Choice of IT Pros Since 1985
StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales.
The RJ919WALLO is backed by a StarTech.com a lifetime warranty and free lifetime technical support.
  • Easy, Hassle-Free Installation
    The wall mount open-frame rack is 17 in. (43.1 cm) deep, so it's perfect for smaller spaces. It ships fully assembled and features mounting holes that are spaced 16 in. apart, making it suitable for mounting on almost any wall, based on common wall-frame stud spacing.
  • Free Up Space
    You can mount the wall mount open-frame rack where space is limited, such as on a server room wall, office, or above a doorway, to expand your workspace and ensure your equipment is easy to access.
  • Keep Your Equipment Cool and Accessible
    By having an open frame, the small wall mount network rack provides passive cooling to equipment. Additionally, the open frame provides easy access and the ability to configure your equipment, allowing you to maximize productivity.
  • The Choice of IT Pros Since 1985
    StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales. The RJ919WALLO is backed by a StarTech.com lifetime warranty and free lifetime technical support.
StarTech.com 9U 19" Wall Mount Network Rack 17" Deep 2 Post Open Frame for Server Room/Data/AV/IT/Communication/Computer Equipment/Patch Panel w/ Cage Nuts/Screws Hook/Loop 175lb Capacity - Wallmount Server Rack (RK919WALLO) - rack - 9U
Rack
Rack Type
Open frame - 2-post
Placing / Mounting
Wall mountable
Package Content
24 M6 screws, 24 M6 cage nuts, 10 ft black hook-and-loop roll
Rack Size
19"
Height (Rack Units)
9U
Product Material
Steel
50.3 cm x 30.3 cm x 47.7 cm
11.8 kg
Rack
Rack Type
Open frame
Rack Post Qty
2-post
Placing / Mounting
Wall mountable
Product Material
Steel
Package Content
Rack Size
19"
Height (Rack Units)
9U
50.3 cm
30.3 cm
47.7 cm
11.8 kg
62 cm x 52.5 cm x 61 cm / 11.9 kg
Weight Limit
80 kg
ECA-310-E, EIA-310-C, RoHS, REACH
Limited warranty: - lifetime
FP9S StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails In Stock £79.46
FP9S StarTech.com 1U Rack Blank Panel for 19in Server Racks and Cabinets In Stock £8.24
FP9S StarTech.com 19in Cable Management Panel In Stock £24.18
FP9S StarTech.com 1U Server Rack Shelf - 16in. Deep - EIA/ECA-310 Compliant In Stock £39.75
FP9S StarTech.com 6U Wall-mount Rack - Open Frame - 2 Post - 18 in. Deep - 175lb. Weight Capacity In Stock £113.53
