Provide a fan and heatsink cooling solution to any standard socket 775/T desktop CPU. This socket T/775 cooler is designed specifically for the Intel socket 775 (socket T) range of processors, including Intel Core 2 Duo and Intel Core 2 Quad, Core 2 Duo Extreme CPUs.
The CPU cooler features a large aluminum heatsink that maximizes dissipation of the heat around the CPU, as well a low-noise 95mm fan that provides up to 50 cfm of air circulation, helping to keep the CPU cooler for optimized performance.
The socket 775/T cooler/fan offers simple installation, providing tool-less clips for easy connection to the motherboard.
The socket 775/socket T CPU cooler is a dependable, high quality CPU cooling solution.
- StarTech.com 95mm Socket T 775 CPU Cooler Fan with Heatsink - socket 775 cooler - lga 775 cooler - 775 cpu cooler (FAN775E) - processor cooler
- Product Type
- Processor cooler
- Black
- Compatibility
- LGA775 Socket
- Heatsink Material
- Aluminium
- Fan Diameter
- 95 mm
- Fan Height
- 25 mm
- Fan Bearing
- Ever Lubricate bearing
- Rotation Speed
- 2800 rpm
- Air Flow
- 49.4 cfm
- Power Connector
- 3-pin plug
- 9.5 cm x 9.5 cm x 6.8 cm
- 374 g
- 2-year warranty
- Product Type
- Processor cooler
- 9.5 cm
- 9.5 cm
- 6.8 cm
- 374 g
- Black
Heatsink & Fan
- Compatible With
- LGA775 Socket
- Heatsink Material
- Aluminium
- Fan Diameter
- 95 mm
- Fan Height
- 25 mm
- Fan Bearing
- Rotation Speed
- 2800 rpm
- Air Flow
- 49.4 cfm
- Power Connector
- 3-pin plug
- RoHS
- Limited warranty: - 2 years
- Sound Emission
- 22.2 dBA
