This 9.2cm x 9.2cm x 2.5cm (3 5/8" x 3 5/8" x 1") dual ball bearing PC case fan is an add-in cooling fan designed to fit most computers. The PC case fan can be used to circulate cool air into the case or exhaust warm air out, preventing problems due to overheating components.
A quiet running brushless ball bearing DC motor coupled with a high efficiency blade design is capable of moving 39.35 CFM (cubic feet per minute) of air.
Power is supplied to the fan using a standard LP4 (hard drive power connector) pass through plug.
- StarTech.com 92x25mm Dual Ball Bearing Computer Case Fan w/ LP4 Connector - 90mm Fan - computer case Fan - pc Fan (FANBOX92) - system fan kit
- Product Type
- System fan kit
- Fan Diameter
- 92 mm
- Noise Level
- 32 dB
- 9.2 cm x 2.5 cm x 9.2 cm
- 1-year warranty
- Product Type
- System fan kit
- 9.2 cm
- 2.5 cm
- 9.2 cm
Heatsink & Fan
- Fan Diameter
- 92 mm
- Noise Level
- 32 dB
- Limited warranty: - 1 year - carry-in
StarTech.com 92x25mm Dual Ball Bearing Computer Case Fan with LP4 Connector | In Stock | £5.77 |
StarTech.com 80x25mm Dual Ball Bearing Computer Case Fan with LP4 Connector | In Stock | £6.57 |
StarTech.com Mounting PC Case Fan Screws - 50 Pack | In Stock | £2.72 |
StarTech.com 80x25mm Dual Ball Bearing Computer Case Fan with TX3 Connector | In Stock | £5.36 |
