StarTech.com 92x25mm Ball Bearing Quiet Computer Case Fan with TX3 Connector
CLEARANCE!
Clearance
Last Few Remaining
Quicklinx: 403VWS00 Mfr#: FAN9X25TX3L
Type: Case Fan
20 In Stock
£5.98 ex VAT
£7.17 inc VAT
Keeping a computer cooled is the best way to increase its efficiency and power. A quiet-running fan can ensure that your computer runs smoothly without disruptive, noisy operation.
StarTech.com 92x25mm Ball Bearing Quiet Computer Case Fan w/ TX3 Connector - 3 pin case Fan - TX3 Fan - 90mm Fan (FAN9X25TX3L) - system fan kit
System fan kit
Fan Diameter
92 mm
Noise Level
25 dBA
9.2 cm x 2.5 cm x 9.2 cm
System fan kit
9.2 cm
2.5 cm
9.2 cm
Heatsink & Fan
Fan Diameter
92 mm
Noise Level
25 dBA
Limited warranty: - 2 years - carry-in
Type: Case Fan
