StarTech.com 90x25mm High Air Flow Dual Ball Bearing Computer Case Fan with TX3
Quicklinx: 9CQ6WS00 Mfr#: FAN9X25TX3H
Type: Case Fan
Hurry, only 1 left in stock!
£7.23 ex VAT
£8.67 inc VAT
Keeping a computer cooled is the best way to increase its efficiency and power. A high-airflow fan can ensure that your computer runs smoothly and is kept at a constantly lower temperature than with normal fans. High airflow circulates hot air around the case and exhausts it out the back.
  • Efficient cooling performance
    This fan is designed to provide high airflow, which is essential for maintaining optimal temperatures in computer systems. It effectively circulates air, helping to prevent overheating during heavy usage.
  • Quiet operation
    With a noise level of 33 dBA, this fan ensures a serene computing environment. It balances performance and quietness, making it suitable for workstations and home setups alike.
StarTech.com 90x25mm High Air Flow Dual Ball Bearing Computer Case Fan w/ TX3 (FAN9X25TX3H) - system fan kit
System fan kit
Fan Diameter
92 mm
Noise Level
33 dBA
1-year warranty
System fan kit
Heatsink & Fan
Fan Diameter
92 mm
Noise Level
33 dBA
Limited warranty: - 1 year
Type: Case Fan
