Allows Serial Slot plate connections to Small Form Factor motherboards in Low Profile enclosures. The PLATE9MHDLP low profile DB9 Serial Slot Plate Adapter Bracket adds a DB9 serial port to the rear panel of small form factor/low profile computer, connecting to the host computer motherboard using a mini style header connector (required by motherboards such as the Intel DG41).
- StarTech.com Serial to 10 Pin IDC Header LP Slot Plate - serial adapter - DB-9 to 10 PIN IDC - 22.9 cm
- Serial adapter
- Low profile
- Length
- 22.9 cm
- Connector
- 9 pin D-Sub (DB-9) - male
- Connector (Second End)
- 10 PIN IDC - female
- Grey
- Limited lifetime warranty
- Serial adapter
- American Wire Gauge (AWG)
- 28
- Low profile
- Length
- 22.9 cm
- Grey
- Connector
- RoHS
